BobN
Why doesn't Video Mixer IP complete synthesis in Vivado 2020.2?
I am trying to build a reference design on Kintex-7 that uses the Video Mixer IP and was designed in Vivado 2020.2.
When I try to implement, the synthesis gets stuck at the Video Mixer (as shown in the attached image)
Is there a solution to this?
aher
Can you please post log file to understand at what stage synthesis is getting stuck?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
BobN
Shreyas,
There is no log output for the Video Mixer IP Synthesis.
I am attaching one for an IP that synthesized correctly, namely the Video Processing Subsytem.
Also attaching messages.
BN
watari
Professor
Professor
Hi @BobN
Refer the following AR.
https://www.xilinx.com/support/answers/70421.html
If you'd like to fix this issue on Windows, I suggest you to refer the following URL to resolve path length issue on Windows.
https://docs.microsoft.com/en-us/windows/win32/fileio/maximum-file-path-limitation?tabs=cmd
Hope this help.
Best regards,
BobN
Thanks, Prof Watari, but my Windows path length was optimized.
I had to resolve this issue by running a Ubuntu (Linux) 18.04 VM on Windows and building the Vivado project within Linux
BN
