chaol
XSG 9.2 DDS5.0 problem
I ran my model under system generator 9.2  today, there is an erroe messagge about DDC 5.0
--------------------------------- Version Log ----------------------------------
Version                                 Path
System Generator 9.2.01.1028            C:/Xilinx/dsptools/9.2.01.1028/sysgen
AccelDSP 9.2.01.1028                    C:/Xilinx/dsptools/9.2.01.1028/AccelDSP
Matlab 7.4.0.287 (R2007a)               C:/Matlab2007a
ISE 9.2.04i                             C:/Xilinx92i
ISE 9.2i IP Update 1                    C:/Xilinx92i
ISE 9.2i IP Update 2                    C:/Xilinx92i
Summary of Errors:
Error 0001: Internal Error
     Block: 'ddc_new_fixedpoint_sundance6/FPGA DDC/DDS v5_0 '
Error 0001:
Reported by:
Details:
An internal error occurred in the Xilinx Blockset Library.
Please report this error to Xilinx (http://support.xilinx.com),
in as much detail as possible. You may also find immediate help
in the Answers Database and other online resources at http://support.xilinx.com.
Error occurred during "Rate and Type Error Checking".
But it worked before, and it can run totally OK under system generator 10.1.But I need use  system generator 9.2 to generate the VHDL code becuase our system compile the code using ISE9.2 chain.
Or is that any compatible problem if I use system generator 10.1 to generate the model and use ISE 9.2 compile them.
Thanks and Best Regards,
Charlie
rjduran
Sysgen models created with a newer version are not backwards compatible. The best thing to do is either go back to 9.2 and create the model or stick with 10.1.
What happens with the model in 10.1?
What do you mean it was working previously?
RJ Duran
Customer Application Engineer
Technical Support: http://www.xilinx.com/support
Xilinx User Community: http://forums.xilinx.com
chaol
This model can run very well in 10.1
When I post this question to you, I couldn't run this model. But now, after I restart the computer, the model can run again without any change.
I don't know why. It also happened before.
Charlie
chaol
The screen snapshots are attached.
chaol
chaol
