JohnsonHu
XVphy_HdmiInitialize is not exist in 2020.1 BSP
Based on a reference code in physs.c, there is a XVPhyss_PowerOnInit() by the function
XVphy_HdmiInitialize()
However, as the BSP  generated by VIVADO 2020.1, there are no such a function call. Please advise if there is a substitute ?
Johnson
florentw
HI @JohnsonHu
You might want to refer to the example design to know how to update the code.
You can see in the following source file that the function XVphy_HdmiInitialize has been deprecated and replaced by * XVphy_Hdmi_CfgInitialize
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/vphy/src/xvphy.h#L68
Florent
florentw
Hi @JohnsonHu
Where did you find the reference code physs.c?
Florent
JohnsonHu
Hi Florent:
Thanks for the follow-up.
The reference code "physs.c",inheriedt from ex-engineer's folder, running well under VIVADO 2016.4. however, as the SDK tool is upgraded to VITIS 2010.1, the function "XVphy_HdmiInitialize" is gone from BSP. I don't think the HDMI-PHY could work if this initialization step is skipped. Please help.
Johnson
florentw
HI @JohnsonHu
Florent
