kannan
Xilinx Gamma LUT IP
     We are trying to implement an image processing pipeline involving Gamma LUT. Our pipeline consists of these IPs.
1.Video stream to AXI
2.Demosaic
3.Gamma LUT
4.VPSS
Without Gamma LUT we are able to obtain proper output.But when I include the Gamma LUT, some kind of noise comes into picture. To debug this I used gamma value 1 and loaded the table with values 0 to 255.
I am using XV_gamma_lut_Write_HwReg_gamma_lut_0_Bytes this function to load the values.
My SDK is
XV_gamma_lut_DisableAutoRestart(gamma_lut_ptr);
                    XV_gamma_lut_Set_HwReg_width(gamma_lut_ptr, 400);
                    XV_gamma_lut_Set_HwReg_height(gamma_lut_ptr, 400);
                    XV_gamma_lut_Set_HwReg_video_format(gamma_lut_ptr, 0);
                    XV_gamma_lut_Write_HwReg_gamma_lut_0_Bytes(gamma_lut_ptr,0,(char *)gamma_lut_values,256);
                    XV_gamma_lut_Write_HwReg_gamma_lut_1_Bytes(gamma_lut_ptr,0,(char *)gamma_lut_values,256);
                    XV_gamma_lut_Write_HwReg_gamma_lut_2_Bytes(gamma_lut_ptr,0,(char *)gamma_lut_values,256);
                    XV_gamma_lut_EnableAutoRestart(gamma_lut_ptr);
                    XV_gamma_lut_Start(gamma_lut_ptr);
u8 gamma_lut_values[256] = {0,1,2,3,4,5,6,7,8,9,10,
        11,12,13,14,15,16,17,18,19,20,
        21,22,23,24,25,26,27,28,29,30,
        31,32,33,34,35,36,37,38,39,40,
        41,42,43,44,45,46,47,48,49,50,
        51,52,53,54,55,56,57,58,59,60,
        61,62,63,64,65,66,67,68,69,70,
        71,72,73,74,75,76,77,78,79,80,
        81,82,83,84,85,86,87,88,89,90,
        91,92,93,94,95,96,97,98,99,100,
        101,102,103,104,105,106,107,108,109,110,
        111,112,113,114,115,116,117,118,119,120,
        121,122,123,124,125,126,127,128,129,130,
        131,132,133,134,135,136,137,138,139,140,
        141,142,143,144,145,146,147,148,149,150,
        151,152,153,154,155,156,157,158,159,160,
        161,162,163,164,165,166,167,168,169,170,
        171,172,173,174,175,176,177,178,179,180,
        181,182,183,184,185,186,187,188,189,190,
        191,192,193,194,195,196,197,198,199,200,
        201,202,203,204,205,206,207,208,209,210,
        211,212,213,214,215,216,217,218,219,220,
        221,222,223,224,225,226,227,228,229,230,
        231,232,233,234,235,236,237,238,239,240,
        241,242,243,244,245,246,247,248,249,250,
        251,252,253,254,255};
Tags (2)
florentw
Hi @kannan,
I am not sure if it is really wrong. It seems that the white part are becoming black and the black part are becoming white. From what I understand you give the value 255 to all the component with the value 0 and the value 0 to all the components with the value 255.
I would say that if you fill the value in the other way (255 to 0), you might get the same image.
Florent
florentw
Hi @kannan,
Florent
kannan
I solved the problem by using XAPP 794 reference design. Now it is working fine.
Kannan
