08-07-2020 04:15 AM
I am trying to test Xilinx Multi-scaler IP over Zynq 7030. I based the block design on the Multi-scaler IP Example. I sucesfully generate the bitstream / XSA but when we try to build the BSP I get an error because my BSP do not have Video Common Library (xv_multi_scaler_l2.c:42:10: fatal error: xvidc.h: No such file or directory).
I test it with 2018.3 and Vitis 2019.2 and I get the same error.
In the Multi-Scaler IP documentation say that support Zynq 7000 and Ultrascale+. How I could include Video Common library to my BSP?
Best regards
08-07-2020 07:06 AM - edited 08-07-2020 07:19 AM
Hi @calcius
I believe I know what is the issue.
Can you try to add the following line to the file <Xilinx_installation_folder>Vitis\2019.2\data\embeddedsw\XilinxProcessorIPLib\drivers\v_multi_scaler_v1_0\data\v_multi_scaler.mdd
OPTION DEPENDS = (video_common);
I am trying to reproduce on my side. If this is the issue, it should affect any 7-series project and any KU/KU+/VU/VU+.
I think this is working fine on the ZU+ devices because the DP controller driver will call the video_common driver. This is why this issue is not happening on the example design
Hope that helps
Hi @calcius
Hope that helps
08-07-2020 08:36 AM
Hi @calcius
I was able to reproduce the issue. I confirmed that the workaround I gave is working.
I have reported the issue to the development team to get a fix for 2020.2
08-24-2020 05:23 AM - edited 08-24-2020 05:37 AM
Thanks @florentw ,
I was out the office last days. I try it now and it build fine with 2019.2 and 2018.3
Best regards
