Xilinx SDK 2016.4 ADV7511 reference design zc702 compile error
Before running the program FPGA on SDK 2016.4, I'm getting these errors :
Description    Resource    Path    Location    Type
error: sw.elf uses VFP register arguments, /home/vconnect/Downloads/adv7511/hdl-hdl_2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/lib/libHDMI_ZynqLib.a(7511_hal.o)   sw             C/C++ Problem
failed to merge target specific data of file /home/vconnect/Downloads/adv7511/hdl-hdl_2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/lib/libHDMI_ZynqLib.a(7511_hal.o)    sw             C/C++ Problem
make: *** [sw.elf] Error 1    sw             C/C++ Problem
recipe for target 'sw.elf' failed    makefile    /sw/Debug    line 39    C/C++ Problem
undefined reference to `XDmaPs_Instr_DMAEND'    cf_hdmi.c    /sw/src    line 232    C/C++ Problem
I've downloaded the correct reference design for 2016.4.
Please help me out with this issue.
Hi @sagar8446,
This might be a question more for Analog Devices than for Xilinx as this is their project...
I would first make sure that you are using the version of Vivado/SDK they recommend. Did you check you are using the correct one?
I tried to solve some of the problems but still stuck with these problems:
In function `AudioClick':
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:220: undefined reference to `XDmaPs_Instr_DMAMOV'
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:221: undefined reference to `XDmaPs_Instr_DMAMOV'
makefile:39: recipe for target 'sw.elf' failed
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:223: undefined reference to `XDmaPs_Instr_DMAMOV'
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:226: undefined reference to `XDmaPs_Instr_DMALP'
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:227: undefined reference to `XDmaPs_Instr_DMALD'
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:228: undefined reference to `XDmaPs_Instr_DMAST'
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:229: undefined reference to `XDmaPs_Instr_DMALPEND'
/home/vconnect/Downloads/adv7511/hdl-2017_r1/projects/adv7511/zc702/adv7511_zc702.sdk/sw/Debug/../src/cf_hdmi.c:232: undefined reference to `XDmaPs_Instr_DMAEND'
Please help me out with these errors...
Hi @sagar8446,
I also get the same problem.my vivado is 2016.4,so hdl ues hdl_2017_r1(it's right version).And as for SDK ,I use no-OS-master /no-OS-2017_R1. I sure  that verison is no problem,but I get the prblem.
Could you tell me how to fix it?
thank you .
