bobvanelst
Xorg issues on Ultra96v2 board (ZU3EG)
I'm trying to get Xorg running on my Ultra96v2 board. It's running on 4 Arm a53 cores and a mali-400 gpu. I used peatlinux 2018.3 to generate the kernel and I have a custom rootfs (archlinuxarm) that's different from the base peatlinux rootfs but I have added all the modules from peatlinux to my new one and everything (wifi, bluetooth, gpio, pl-axi, etc) except the displayport(xorg) works. I get a terminal on my screen through the displayport but can't start X server to run graphical applications.
Things I've tried:
1. Precompiled armsoc_drv.so from peatlinux rootfs (had version miss match error xorg)
2. compiled armsoc from https://github.com/endlessm/xf86-video-armsoc (permission denied drm)
3. xorg.conf with driver as "armsoc" (permission denied drm)
4. added user alarm to group video (permission denied drm)
5. ran startx in root user (failed to open /dev/umplock/ Screen(s) found, but none have a usable configuration)
1. no xorg.conf (Segmentation fault)
[alarm@alarm ~]$ cat .local/share/xorg/Xorg.0.log
[ 7860.274] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 7860.279]
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
[ 7860.291] Build Operating System: Linux Arch Linux
[ 7860.296] Current Operating System: Linux alarm 4.14.0-xilinx-v2018.3 #1 SMP Tue Nov 19 09:20:02 UTC 2019 aarch64
[ 7860.296] Kernel command line: console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait sdhci.debug_quirks=64 cpuidle.off=1
[ 7860.305] Build Date: 26 October 2019 06:18:57AM
[ 7860.309]
[ 7860.314] Current version of pixman: 0.38.4
[ 7860.323] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 7860.323] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 7860.341] (==) Log file: "/home/alarm/.local/share/xorg/Xorg.0.log", Time: Tue Nov 19 12:56:25 2019
[ 7860.346] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 7860.346] (==) No Layout section. Using the first Screen section.
[ 7860.346] (==) No screen section available. Using defaults.
[ 7860.346] (**) |-->Screen "Default Screen Section" (0)
[ 7860.347] (**) | |-->Monitor "<default monitor>"
[ 7860.347] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 7860.347] (==) Automatically adding devices
[ 7860.347] (==) Automatically enabling devices
[ 7860.347] (==) Automatically adding GPU devices
[ 7860.348] (==) Automatically binding GPU devices
[ 7860.348] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7860.348] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 7860.348] Entry deleted from font path.
[ 7860.348] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 7860.348] (WW) The directory "/usr/share/fonts/TTF" does not exist.
[ 7860.348] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 7860.348] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 7860.348] (==) FontPath set to:
/usr/share/fonts/100dpi,
/usr/share/fonts/75dpi
[ 7860.348] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 7860.348] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 7860.348] (II) Module ABI versions:
[ 7860.348] X.Org ANSI C Emulation: 0.4
[ 7860.348] X.Org Video Driver: 24.0
[ 7860.348] X.Org XInput driver : 24.1
[ 7860.348] X.Org Server Extension : 10.0
[ 7860.350] (++) using VT number 1
[ 7860.354] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 7860.355] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 7860.356] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 7860.356] (II) no primary bus or device found
[ 7860.357] falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-display/drm/card0
[ 7860.357] (II) LoadModule: "glx"
[ 7860.357] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7860.376] (II) Module glx: vendor="X.Org Foundation"
[ 7860.376] compiled for 1.20.5, module version = 1.0.0
[ 7860.376] ABI class: X.Org Server Extension, version 10.0
[ 7860.376] (==) Matched modesetting as autoconfigured driver 0
[ 7860.376] (==) Matched fbdev as autoconfigured driver 1
[ 7860.376] (==) Assigned the driver to the xf86ConfigLayout
[ 7860.376] (II) LoadModule: "modesetting"
[ 7860.377] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 7860.397] (II) Module modesetting: vendor="X.Org Foundation"
[ 7860.397] compiled for 1.20.5, module version = 1.20.5
[ 7860.397] Module class: X.Org Video Driver
[ 7860.397] ABI class: X.Org Video Driver, version 24.0
[ 7860.397] (II) LoadModule: "fbdev"
[ 7860.397] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 7860.399] (II) Module fbdev: vendor="X.Org Foundation"
[ 7860.399] compiled for 1.20.0, module version = 0.5.0
[ 7860.399] Module class: X.Org Video Driver
[ 7860.399] ABI class: X.Org Video Driver, version 24.0
[ 7860.400] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 7860.400] (II) FBDEV: driver for framebuffer: fbdev
[ 7860.400] (II) modeset(0): using drv /dev/dri/card0
[ 7860.400] (WW) Falling back to old probe method for fbdev
[ 7860.400] (II) Loading sub module "fbdevhw"
[ 7860.400] (II) LoadModule: "fbdevhw"
[ 7860.400] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 7860.403] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 7860.403] compiled for 1.20.5, module version = 0.0.2
[ 7860.403] ABI class: X.Org Video Driver, version 24.0
[ 7860.403] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 7860.403] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 7860.403] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 7860.403] (==) modeset(0): RGB weight 888
[ 7860.403] (==) modeset(0): Default visual is TrueColor
[ 7860.404] (II) Loading sub module "glamoregl"
[ 7860.404] (II) LoadModule: "glamoregl"
[ 7860.404] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 7860.470] (II) Module glamoregl: vendor="X.Org Foundation"
[ 7860.471] compiled for 1.20.5, module version = 1.0.1
[ 7860.471] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7863.077] (EE) modeset(0): eglGetDisplay() failed
[ 7863.111] (EE) modeset(0): glamor initialization failed
[ 7863.111] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 7863.692] (II) modeset(0): Output DP-1 has no monitor section
[ 7863.782] (II) modeset(0): EDID for output DP-1
[ 7863.782] (II) modeset(0): Manufacturer: DEL Model: a0ba Serial#: 859395148
[ 7863.782] (II) modeset(0): Year: 2019 Week: 8
[ 7863.782] (II) modeset(0): EDID Version: 1.3
[ 7863.782] (II) modeset(0): Digital Display Input
[ 7863.782] (II) modeset(0): Max Image Size [cm]: horiz.: 52 vert.: 32
[ 7863.782] (II) modeset(0): Gamma: 2.20
[ 7863.782] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 7863.783] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 7863.783] (II) modeset(0): First detailed timing is preferred mode
[ 7863.783] (II) modeset(0): redX: 0.660 redY: 0.332 greenX: 0.302 greenY: 0.613
[ 7863.783] (II) modeset(0): blueX: 0.150 blueY: 0.063 whiteX: 0.313 whiteY: 0.329
[ 7863.783] (II) modeset(0): Supported established timings:
[ 7863.783] (II) modeset(0): 720x400@70Hz
[ 7863.783] (II) modeset(0): 640x480@60Hz
[ 7863.783] (II) modeset(0): 640x480@75Hz
[ 7863.783] (II) modeset(0): 800x600@60Hz
[ 7863.783] (II) modeset(0): 800x600@75Hz
[ 7863.783] (II) modeset(0): 1024x768@60Hz
[ 7863.783] (II) modeset(0): 1024x768@75Hz
[ 7863.783] (II) modeset(0): 1280x1024@75Hz
[ 7863.783] (II) modeset(0): Manufacturer's mask: 0
[ 7863.783] (II) modeset(0): Supported standard timings:
[ 7863.783] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 7863.783] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 7863.783] (II) modeset(0): #2: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 7863.783] (II) modeset(0): #3: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 7863.783] (II) modeset(0): #4: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 7863.783] (II) modeset(0): Supported detailed timing:
[ 7863.783] (II) modeset(0): clock: 154.0 MHz Image Size: 518 x 324 mm
[ 7863.783] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 7863.783] (II) modeset(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
[ 7863.783] (II) modeset(0): Serial No: 7MT0192I39TL
[ 7863.783] (II) modeset(0): Monitor name: DELL U2415
[ 7863.783] (II) modeset(0): Ranges: V min: 49 V max: 61 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 7863.783] (II) modeset(0): clock: 148.5 MHz Image Size: 518 x 324 mm
[ 7863.783] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 7863.783] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 7863.783] (II) modeset(0): clock: 74.2 MHz Image Size: 518 x 324 mm
[ 7863.784] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 7863.784] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 7863.784] (II) modeset(0): Supported detailed timing:
[ 7863.784] (II) modeset(0): clock: 74.2 MHz Image Size: 518 x 324 mm
[ 7863.784] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 7863.784] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 7863.784] (II) modeset(0): clock: 27.0 MHz Image Size: 518 x 324 mm
[ 7863.784] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 7863.784] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 7863.784] (II) modeset(0): Number of EDID sections to follow: 1
[ 7863.784] (II) modeset(0): EDID (in hex):
[ 7863.784] (II) modeset(0): 00ffffffffffff0010acbaa04c543933
[ 7863.784] (II) modeset(0): 081d010380342078ea0495a9554d9d26
[ 7863.784] (II) modeset(0): 105054a54b00714f8180a940d1c0d100
[ 7863.784] (II) modeset(0): 010101010101283c80a070b023403020
[ 7863.784] (II) modeset(0): 360006442100001e000000ff00374d54
[ 7863.784] (II) modeset(0): 30313932493339544c0a000000fc0044
[ 7863.784] (II) modeset(0): 454c4c2055323431350a2020000000fd
[ 7863.784] (II) modeset(0): 00313d1e5311000a20202020202001b0
[ 7863.784] (II) modeset(0): 020322f14f9005040302071601141f12
[ 7863.784] (II) modeset(0): 132021222309070765030c0010008301
[ 7863.784] (II) modeset(0): 0000023a801871382d40582c45000644
[ 7863.784] (II) modeset(0): 2100001e011d8018711c1620582c2500
[ 7863.784] (II) modeset(0): 06442100009e011d007251d01e206e28
[ 7863.784] (II) modeset(0): 550006442100001e8c0ad08a20e02d10
[ 7863.784] (II) modeset(0): 103e9600064421000018000000000000
[ 7863.784] (II) modeset(0): 00000000000000000000000000000082
[ 7863.785] (II) modeset(0): Printing probed modes for output DP-1
[ 7863.785] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync +vsync (74.0 kHz eP)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 7863.785] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 7863.785] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 7863.785] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 7863.785] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 7863.785] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 7863.785] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 7863.785] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 7863.785] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7863.786] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7863.786] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 7863.786] (II) modeset(0): Output DP-1 connected
[ 7863.786] (II) modeset(0): Using exact sizes for initial modes
[ 7863.786] (II) modeset(0): Output DP-1 using initial mode 1920x1200 +0+0
[ 7863.786] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7863.786] (==) modeset(0): DPI set to (96, 96)
[ 7863.786] (II) Loading sub module "fb"
[ 7863.786] (II) LoadModule: "fb"
[ 7863.786] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7863.794] (II) Module fb: vendor="X.Org Foundation"
[ 7863.794] compiled for 1.20.5, module version = 1.0.0
[ 7863.794] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7863.794] (II) UnloadModule: "fbdev"
[ 7863.794] (II) Unloading fbdev
[ 7863.794] (II) UnloadSubModule: "fbdevhw"
[ 7863.794] (II) Unloading fbdevhw
[ 7863.814] (==) modeset(0): Backing store enabled
[ 7863.814] (==) modeset(0): Silken mouse disabled
[ 7863.861] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 7863.861] (==) modeset(0): DPMS enabled
[ 7863.861] (II) Initializing extension Generic Event Extension
[ 7863.861] (II) Initializing extension SHAPE
[ 7863.861] (II) Initializing extension MIT-SHM
[ 7863.861] (II) Initializing extension XInputExtension
[ 7863.869] (II) Initializing extension XTEST
[ 7863.869] (II) Initializing extension BIG-REQUESTS
[ 7863.869] (II) Initializing extension SYNC
[ 7863.869] (II) Initializing extension XKEYBOARD
[ 7863.869] (II) Initializing extension XC-MISC
[ 7863.869] (II) Initializing extension SECURITY
[ 7863.870] (II) Initializing extension XFIXES
[ 7863.870] (II) Initializing extension RENDER
[ 7863.870] (II) Initializing extension RANDR
[ 7863.870] (II) Initializing extension COMPOSITE
[ 7863.870] (II) Initializing extension DAMAGE
[ 7863.870] (II) Initializing extension MIT-SCREEN-SAVER
[ 7863.870] (II) Initializing extension DOUBLE-BUFFER
[ 7863.871] (II) Initializing extension RECORD
[ 7863.871] (II) Initializing extension DPMS
[ 7863.871] (II) Initializing extension Present
[ 7863.871] (II) Initializing extension DRI3
[ 7863.871] (II) Initializing extension X-Resource
[ 7863.871] (II) Initializing extension XVideo
[ 7863.871] (II) Initializing extension XVideo-MotionCompensation
[ 7863.871] (II) Initializing extension GLX
[ 7863.871] (II) AIGLX: Screen 0 is not DRI2 capable
[ 7863.893] (II) IGLX: Loaded and initialized swrast
[ 7863.893] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 7863.893] (II) Initializing extension XFree86-VidModeExtension
[ 7863.893] (II) Initializing extension XFree86-DGA
[ 7863.893] (II) Initializing extension XFree86-DRI
[ 7863.893] (II) Initializing extension DRI2
[ 7863.893] (EE)
[ 7863.893] (EE) Backtrace:
[ 7863.900] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x5c) [0x55676dfd2c]
[ 7863.900] (EE) 1: /usr/lib/Xorg (0x55675a2000+0x1411e8) [0x55676e31e8]
[ 7863.900] (EE) 2: linux-vdso.so.1 (__kernel_rt_sigreturn+0x0) [0x7f931ae66c]
[ 7863.900] (EE) 3: /usr/lib/xorg/modules/drivers/modesetting_drv.so (0x7f91ed6000+0x11650) [0x7f91ee7650]
[ 7863.900] (EE) 4: /usr/lib/xorg/modules/drivers/modesetting_drv.so (0x7f91ed6000+0x1134c) [0x7f91ee734c]
[ 7863.900] (EE) 5: /usr/lib/xorg/modules/drivers/modesetting_drv.so (0x7f91ed6000+0xab00) [0x7f91ee0b00]
[ 7863.900] (EE) 6: /usr/lib/Xorg (0x55675a2000+0x182c28) [0x5567724c28]
[ 7863.901] (EE) 7: /usr/lib/Xorg (0x55675a2000+0x7738c) [0x556761938c]
[ 7863.901] (EE) 8: /usr/lib/libc.so.6 (__libc_start_main+0xe4) [0x7f92ced6e4]
[ 7863.901] (EE) 9: /usr/lib/Xorg (0x55675a2000+0x41268) [0x55675e3268]
[ 7863.901] (EE)
[ 7863.901] (EE) Segmentation fault at address 0x8
[ 7863.901] (EE)
Fatal server error:
[ 7863.901] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 7863.901] (EE)
[ 7863.901] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 7863.901] (EE) Please also check the log file at "/home/alarm/.local/share/xorg/Xorg.0.log" for additional information.
[ 7863.901] (EE)
[ 7863.926] (EE) Server terminated with error (1). Closing log file.
2. With armsoc as normal user (Permission denied)
[alarm@alarm ~]$ less .local/share/xorg/Xorg.0.log
[ 7282.891] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 7282.895]
[ 7282.905] Build Operating System: Linux Arch Linux
[ 7282.908] Current Operating System: Linux alarm 4.14.0-xilinx-v2018.3 #1 SMP Tue Nov 19 09:20:02 UTC 2019 aarch64
[ 7282.908] Kernel command line: console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait sdhci.debug_quirks=64 cpuidle.off=1
[ 7282.916] Build Date: 26 October 2019 06:18:57AM
[ 7282.919]
[ 7282.923] Current version of pixman: 0.38.4
[ 7282.930] Before reporting problems, check http://wiki.x.org
[ 7282.930] Markers: (--) probed, (**) from config file, (==) default setting,
[ 7282.944] (==) Log file: "/home/alarm/.local/share/xorg/Xorg.0.log", Time: Tue Nov 19 12:46:47 2019
[ 7282.948] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 7282.952] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 7282.952] (==) No Layout section. Using the first Screen section.
[ 7282.952] (==) No screen section available. Using defaults.
[ 7282.952] (**) |-->Screen "Default Screen Section" (0)
[ 7282.952] (**) | |-->Monitor "<default monitor>"
[ 7282.953] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 7282.953] (**) | |-->Device "Mali FBDEV"
[ 7282.953] (==) No monitor specified for screen "Default Screen Section".
[ 7282.953] (==) Automatically adding devices
[ 7282.953] (==) Automatically enabling devices
[ 7282.953] (==) Automatically adding GPU devices
[ 7282.953] (==) Automatically binding GPU devices
[ 7282.953] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7282.953] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 7282.953] Entry deleted from font path.
[ 7282.953] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 7282.953] (WW) The directory "/usr/share/fonts/TTF" does not exist.
[ 7282.954] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 7282.954] Entry deleted from font path.
[ 7282.954] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 7282.954] (==) FontPath set to:
[ 7282.954] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 7282.954] (II) The server relies on udev to provide the list of input devices.
[ 7282.954] (II) Module ABI versions:
[ 7282.954] X.Org ANSI C Emulation: 0.4
[ 7282.954] X.Org Video Driver: 24.0
[ 7282.954] X.Org XInput driver : 24.1
[ 7282.954] X.Org Server Extension : 10.0
[ 7282.955] (++) using VT number 1
[ 7282.959] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 7282.961] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 7282.962] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 7282.962] (II) no primary bus or device found
[ 7282.962] falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-display/drm/card0
[ 7282.962] (II) LoadModule: "glx"
[ 7282.963] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7282.982] (II) Module glx: vendor="X.Org Foundation"
[ 7282.982] compiled for 1.20.5, module version = 1.0.0
[ 7282.982] ABI class: X.Org Server Extension, version 10.0
[ 7282.982] (II) LoadModule: "armsoc"
[ 7282.982] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[ 7282.983] (II) Module armsoc: vendor="X.Org Foundation"
[ 7282.983] compiled for 1.20.0, module version = 0.6.0
[ 7282.983] Module class: X.Org Video Driver
[ 7282.983] ABI class: X.Org Video Driver, version 24.0
[ 7282.983] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[ 7282.983] (WW) Falling back to old probe method for armsoc
[ 7282.983] (II) No BusID or DriverName specified - opening /dev/dri/card0
[ 7282.983] (EE) ERROR: Cannot set the DRM interface version.
[ 7282.983] (EE) ERROR: Cannot open a connection with the DRM - Permission denied
[ 7282.984] (EE) No devices detected.
[ 7282.984] (EE)
Fatal server error:
[ 7282.984] (EE) no screens found(EE)
[ 7282.984] (EE)
for help.
[ 7282.984] (EE) Please also check the log file at "/home/alarm/.local/share/xorg/Xorg.0.log" for additional information.
[ 7282.984] (EE)
[ 7283.005] (EE) Server terminated with error (1). Closing log file.
3. armsoc as root (Screen(s) found, but none have a usable configuration.)
[alarm@alarm ~]$ cat /var/log/Xorg.0.log
[ 99.359] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 99.359]
[ 99.360] Build Operating System: Linux Arch Linux
[ 99.360] Current Operating System: Linux alarm 4.14.0-xilinx-v2018.3 #1 SMP Tue Nov 19 09:20:02 UTC 2019 aarch64
[ 99.360] Kernel command line: console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait sdhci.debug_quirks=64 cpuidle.off=1
[ 99.360] Build Date: 26 October 2019 06:18:57AM
[ 99.360]
[ 99.360] Current version of pixman: 0.38.4
[ 99.361] Before reporting problems, check http://wiki.x.org
[ 99.361] Markers: (--) probed, (**) from config file, (==) default setting,
[ 99.361] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 19 13:02:39 2019
[ 99.361] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 99.362] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 99.362] (==) No Layout section. Using the first Screen section.
[ 99.362] (==) No screen section available. Using defaults.
[ 99.362] (**) |-->Screen "Default Screen Section" (0)
[ 99.362] (**) | |-->Monitor "<default monitor>"
[ 99.363] (==) No device specified for screen "Default Screen Section".
[ 99.363] (**) | |-->Device "Mali FBDEV"
[ 99.363] (==) No monitor specified for screen "Default Screen Section".
[ 99.363] (==) Automatically adding devices
[ 99.363] (==) Automatically enabling devices
[ 99.363] (==) Automatically adding GPU devices
[ 99.363] (==) Automatically binding GPU devices
[ 99.363] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 99.363] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 99.363] Entry deleted from font path.
[ 99.363] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 99.363] (WW) The directory "/usr/share/fonts/TTF" does not exist.
[ 99.363] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 99.363] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 99.363] (==) FontPath set to:
[ 99.363] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 99.363] (II) The server relies on udev to provide the list of input devices.
[ 99.363] (II) Module ABI versions:
[ 99.363] X.Org ANSI C Emulation: 0.4
[ 99.363] X.Org Video Driver: 24.0
[ 99.363] X.Org XInput driver : 24.1
[ 99.363] X.Org Server Extension : 10.0
[ 99.365] (++) using VT number 1
[ 99.369] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 99.370] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 99.371] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 99.372] (II) no primary bus or device found
[ 99.372] falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-display/drm/card0
[ 99.372] (II) LoadModule: "glx"
[ 99.373] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 99.391] (II) Module glx: vendor="X.Org Foundation"
[ 99.392] compiled for 1.20.5, module version = 1.0.0
[ 99.392] ABI class: X.Org Server Extension, version 10.0
[ 99.392] (II) LoadModule: "armsoc"
[ 99.392] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[ 99.392] (II) Module armsoc: vendor="X.Org Foundation"
[ 99.392] compiled for 1.20.0, module version = 0.6.0
[ 99.392] Module class: X.Org Video Driver
[ 99.392] ABI class: X.Org Video Driver, version 24.0
[ 99.392] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[ 99.393] (WW) Falling back to old probe method for armsoc
[ 99.393] (II) No BusID or DriverName specified - opening /dev/dri/card0
[ 99.393] (II) Got BusID fd4a0000.zynqmp-display
[ 99.393] (II) Opened DRM
[ 99.393] (II) DeviceName is [/dev/dri/card0]
[ 99.393] (II) bus_id is [fd4a0000.zynqmp-display]
[ 99.393] (II) DriverName is [xlnx]
[ 99.393] (II) version is [1.0.0]
[ 99.393] (II) Screen:0, CRTC:-1
[ 99.393] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 99.393] (II) ARMSOC(0): Creating default Display subsection in Screen section
[ 99.393] (==) ARMSOC(0): Depth 24, (==) framebuffer bpp 32
[ 99.393] (==) ARMSOC(0): RGB weight 888
[ 99.393] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[ 99.393] (==) ARMSOC(0): Default visual is TrueColor
[ 99.394] (II) DeviceName is [/dev/dri/card0]
[ 99.394] (II) bus_id is [fd4a0000.zynqmp-display]
[ 99.394] (II) DriverName is [xlnx]
[ 99.394] (II) version is [1.0.0]
[ 99.394] (WW) ARMSOC(0): WARNING: Failed to open /dev/umplock.
[ 99.394] (II) UnloadModule: "armsoc"
[ 99.394] (EE) Screen(s) found, but none have a usable configuration.
[ 99.394] (EE)
Fatal server error:
[ 99.394] (EE) no screens found(EE)
[ 99.394] (EE)
for help.
[ 99.394] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 99.394] (EE)
[ 99.450] (EE) Server terminated with error (1). Closing log file.
4. Xorg Mali driver (permission denied)
[ 76.873] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 76.873]
[ 76.873] Build Operating System: Linux Arch Linux
[ 76.874] Current Operating System: Linux alarm 4.14.0-xilinx-v2018.3 #1 SMP Tue Nov 19 09:20:02 UTC 2019 aarch64
[ 76.874] Kernel command line: console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait sdhci.debug_quirks=64 cpuidle.off=1
[ 76.874] Build Date: 26 October 2019 06:18:57AM
[ 76.874]
[ 76.874] Current version of pixman: 0.38.4
[ 76.874] Before reporting problems, check http://wiki.x.org
[ 76.874] Markers: (--) probed, (**) from config file, (==) default setting,
[ 76.875] (==) Log file: "/home/alarm/.local/share/xorg/Xorg.0.log", Time: Tue Nov 19 13:02:16 2019
[ 76.887] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 76.888] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 76.891] (==) No Layout section. Using the first Screen section.
[ 76.891] (==) No screen section available. Using defaults.
[ 76.891] (**) |-->Screen "Default Screen Section" (0)
[ 76.891] (**) | |-->Monitor "<default monitor>"
[ 76.891] (==) No device specified for screen "Default Screen Section".
[ 76.892] (**) | |-->Device "Mali FBDEV"
[ 76.892] (==) No monitor specified for screen "Default Screen Section".
[ 76.892] (==) Automatically adding devices
[ 76.892] (==) Automatically enabling devices
[ 76.892] (==) Automatically adding GPU devices
[ 76.892] (==) Automatically binding GPU devices
[ 76.892] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 76.903] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 76.903] Entry deleted from font path.
[ 76.903] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 76.903] (WW) The directory "/usr/share/fonts/TTF" does not exist.
[ 76.903] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 76.903] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 76.910] (==) FontPath set to:
[ 76.910] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 76.910] (II) The server relies on udev to provide the list of input devices.
[ 76.917] (II) Module ABI versions:
[ 76.917] X.Org ANSI C Emulation: 0.4
[ 76.917] X.Org Video Driver: 24.0
[ 76.917] X.Org XInput driver : 24.1
[ 76.917] X.Org Server Extension : 10.0
[ 76.919] (++) using VT number 1
[ 76.923] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 76.924] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 76.925] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 76.925] (II) no primary bus or device found
[ 76.926] falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-display/drm/card0
[ 76.926] (II) LoadModule: "glx"
[ 76.930] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 77.056] (II) Module glx: vendor="X.Org Foundation"
[ 77.056] compiled for 1.20.5, module version = 1.0.0
[ 77.056] ABI class: X.Org Server Extension, version 10.0
[ 77.056] (II) LoadModule: "armsoc"
[ 77.066] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[ 77.072] (II) Module armsoc: vendor="X.Org Foundation"
[ 77.072] compiled for 1.20.0, module version = 0.6.0
[ 77.072] Module class: X.Org Video Driver
[ 77.072] ABI class: X.Org Video Driver, version 24.0
[ 77.072] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[ 77.073] (WW) Falling back to old probe method for armsoc
[ 77.073] (II) No BusID or DriverName specified - opening /dev/dri/card0
[ 77.073] (EE) ERROR: Cannot set the DRM interface version.
[ 77.073] (EE) ERROR: Cannot open a connection with the DRM - Permission denied
[ 77.073] (EE) No devices detected.
[ 77.073] (EE)
Fatal server error:
[ 77.073] (EE) no screens found(EE)
[ 77.073] (EE)
for help.
[ 77.073] (EE) Please also check the log file at "/home/alarm/.local/share/xorg/Xorg.0.log" for additional information.
[ 77.073] (EE)
[ 77.104] (EE) Server terminated with error (1). Closing log file.
Xorg.conf for armsoc, even without it xorg tries to load it if it's in /usr/lib/xorg/modules/drivers
Section "InputDevice"
Identifier "System Mouse"
Driver "mouse"
Option "Device" "/dev/input/mouse0"
EndSection
Identifier "System Keyboard"
Driver "kbd"
Option "Device" "/dev/input/event0"
EndSection
Section "Device"
Identifier "ZynqMP"
Driver "armsoc"
Option "Fimg2DExa" "false"
Option "fbdev" "/dev/fb0"
Option "DRI2" "true"
Option "DRI2_PAGE_FLIP" "false"
Option "DRI2_WAIT_VSYNC" "true"
Option "SWcursorLCD" "false"
EndSection
Section "Screen"
Identifier "DefaultScreen"
Device "ZynqMP"
DefaultDepth 16
SubSection "Display"
Modes "1920x1080"
EndSubSection
EndSection
Section "ServerFlags"
Option "BlankTime" "0"
Option "StandbyTime" "0"
Option "SuspendTime" "0"
Option "OffTime" "0"
EndSection
Xorg drivers
[alarm@alarm ~]$ ll /usr/lib/xorg/modules/drivers/
total 240
-rwxr-xr-x 1 root root 85944 Jun 28 2018 armsoc_drv.so
-rwxr-xr-x 1 root root 23408 Jun 7 2018 fbdev_drv.so
-rwxr-xr-x 1 root root 102840 Oct 26 06:18 modesetting_drv.so
-rwxr-xr-x 1 root root 27512 May 17 2018 vesa_drv.so
Permissions
[alarm@alarm ~]$ ll /dev/dri/card0
crw-rw----+ 1 root video 226, 0 Nov 19 13:01 /dev/dri/card0
[alarm@alarm ~]$ ll /dev/fb0
crw-rw---- 1 root video 29, 0 Nov 19 13:01 /dev/fb0
[alarm@alarm ~]$ groups
video wheel alarm
Mali driver modinfo
[alarm@alarm ~]$ modinfo mali
filename: /lib/modules/4.14.0-xilinx-v2018.3/extra/mali.ko
version: r8p0-01rel0
author: ARM Ltd.
license: GPL
srcversion: 533BB7E5866E52F63B9ACCB
alias: of:N*T*Carm,mali-470C*
alias: of:N*T*Carm,mali-450C*
alias: of:N*T*Carm,mali-400C*
alias: of:N*T*Carm,mali-300C*
depends:
vermagic: 4.14.0-xilinx-v2018.3 SMP mod_unload aarch64
parm: mali_core_scaling_enable:1 means to enable core scaling policy, 0 means to disable core scaling policy
parm: mali_debug_level:Higher number, more dmesg output (int)
parm: mali_max_job_runtime:Maximum allowed job runtime in msecs.
Jobs will be killed after this no matter what (int)
parm: mali_l2_max_reads:Maximum reads for Mali L2 cache (int)
parm: mali_dedicated_mem_start:Physical start address of dedicated Mali GPU memory. (uint)
parm: mali_dedicated_mem_size:Size of dedicated Mali GPU memory. (uint)
parm: mali_shared_mem_size:Size of shared Mali GPU memory. (uint)
parm: mali_max_pp_cores_group_1:Limit the number of PP cores to use from first PP group. (int)
parm: mali_max_pp_cores_group_2:Limit the number of PP cores to use from second PP group (Mali-450 only). (int)
parm: mali_mem_swap_out_threshold_value:Threshold value used to limit how much swappable memory cached in Mali driver. (uint)
parm: mali_max_system_fps:Max system fps the same as display VSYNC. (int)
parm: mali_desired_fps:A bit lower than max_system_fps which user desired fps (int)
[alarm@alarm ~]$ lsmod
Module Size Used by
zynqmp_r5_remoteproc 16384 0
mali 241664 0
uio_pdrv_genirq 16384 0
wilc_sdio 118784 0
I don't know what I'm missing. I've tried all the options that I could find. I bet the solution is something small that I've overlooked. Anyone have ideas?
Tags (2)
florentw
Hi @bobvanelst
Can you run a modetest command (modetest -M xlnx) and share the input?
Running the modetest (modetest -M xlnx -s 38:1920x1080@RG16) first might help by setting the output resolution/format.
Florent
bobvanelst
@florentw There was no modetest command. I tried compiling it from from source but there's not xlnx. Modprobe also can't find xlnx
$ sudo find / -name "*xlnx*"
/run/udev/data/+platform:xlnx-drm.0
/usr/lib/modules/4.14.0-xilinx-v2018.3/kernel/drivers/soc/xilinx/xlnx_vcu_core.ko
/sys/kernel/debug/xlnx-bridge
/sys/kernel/debug/xlnx-bridge/xlnx_bridge-gfx-layer
/sys/kernel/debug/xlnx-bridge/xlnx_bridge-vid-layer
/sys/devices/platform/amba/fd4a0000.zynqmp-display/xlnx-drm.0
/sys/firmware/devicetree/base/amba/dma@fd520000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/mmc@ff170000/xlnx,mio_bank
/sys/firmware/devicetree/base/amba/mmc@ff170000/xlnx,device_id
/sys/firmware/devicetree/base/amba/dma@fd560000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,enable-trace
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,enable-32bit-filter-id
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,metric-count-scale
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,enable-event-log
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,enable-advanced
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,fifo-axis-tdata-width
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,enable-event-count
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,enable-profile
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,num-of-counters
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,num-monitor-slots
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,metric-count-width
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,fifo-axis-depth
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,have-sampled-metric-cnt
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,fifo-axis-tid-width
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,global-count-width
/sys/firmware/devicetree/base/amba/perf-monitor@ffa00000/xlnx,metrics-sample-count-width
/sys/firmware/devicetree/base/amba/dma@ffab0000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffaf0000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffa80000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/usb0@ff9d0000/xlnx,usb-reset-mode
/sys/firmware/devicetree/base/amba/usb0@ff9d0000/xlnx,usb-polarity
/sys/firmware/devicetree/base/amba/dma@fd530000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@fd570000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffac0000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffa90000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@fd500000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@fd540000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffad0000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@fd510000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/mmc@ff160000/xlnx,mio_bank
/sys/firmware/devicetree/base/amba/mmc@ff160000/xlnx,device_id
/sys/firmware/devicetree/base/amba/usb1@ff9e0000/xlnx,usb-reset-mode
/sys/firmware/devicetree/base/amba/usb1@ff9e0000/xlnx,usb-polarity
/sys/firmware/devicetree/base/amba/dma@fd550000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffaa0000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/dma@ffae0000/xlnx,bus-width
/sys/firmware/devicetree/base/amba/zynqmp-display@fd4a0000/zynqmp_dp_snd_card/xlnx,dp-snd-pcm
/sys/firmware/devicetree/base/amba/zynqmp-display@fd4a0000/zynqmp_dp_snd_card/xlnx,dp-snd-codec
/sys/firmware/devicetree/base/amba/zynqmp-display@fd4a0000/xlnx,max-lanes
/sys/firmware/devicetree/base/mailbox@ff990400/xlnx,ipi-ids
/sys/firmware/devicetree/base/__symbols__/xlnx_dpdma
/sys/firmware/devicetree/base/__symbols__/xlnx_rsa
/sys/firmware/devicetree/base/__symbols__/xlnx_keccak_384
/sys/firmware/devicetree/base/__symbols__/xlnx_aes
/sys/bus/platform/devices/xlnx-drm.0
/sys/bus/platform/drivers/xlnx-mixer
/sys/bus/platform/drivers/xlnx,uhdsdi-tx
/sys/bus/platform/drivers/xlnx-sdi-tx
/sys/bus/platform/drivers/xlnx-sdi-audio
/sys/bus/platform/drivers/xlnx,scaler-bridge
/sys/bus/platform/drivers/xlnx_i2s
/sys/bus/platform/drivers/xlnx-pl-disp
/sys/bus/platform/drivers/xlnx,csc-bridge
/sys/bus/platform/drivers/xlnx,scdma
/sys/bus/platform/drivers/xlnx-scdchan
/sys/bus/platform/drivers/xlnx_pr_decoupler
/sys/bus/platform/drivers/xlnx-drm
/sys/bus/platform/drivers/xlnx-drm/xlnx-drm.0
/sys/bus/platform/drivers/xlnx-dsi
/sys/bus/platform/drivers/xlnx_formatter_pcm
/sys/bus/platform/drivers/xlnx_snd_card
/sys/module/xlnx_drm
florentw
Hi @bobvanelst
I would recommend you to start with petalinux, this way the xilinx sources should be pulled correctly
Florent
