Z7015: timing violation using MIPI CSI-2 RX IP
Hi there,
I'm using the MIPI CSI-2 RX IP in my design with Zynq7015.
I fed the dphy_clk_200M input of the IP with a 200MHz clock generated directly from the ZYNQ processor.
After implementation design, I get the following timing violations (internal to the MIPI CSI-2 IP) in figures below.
How to fix the violation, which seems to be internal to the core? I have already try with a different 200MHz clock, but without success,
Thanks in advance for any help.
Paolo.
karnanl
Hello @paolofalconearesys
1. Are you using 7-series device with slower speed grade ? (ex. -1, -2)
2. We are aware that HS_SETTLE register path has a big logic level that may be hard to close timing for some FPGA design. We already made some improvement on this and new IP is scheduled for 2018.3
3. For now, please set this path as a multi-cycle path to ease the timing.
    set_multicycle_path 2 -from <> -to  <>.
Thanks & regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
karnanl
Thanks & regards
Leo
