02-13-2020 02:37 AM
HI,
I went through the Video Series Tutorial, Video series has example's for demostration of ZC702 for HDMI based Test Pattern Generator.
I am having ZC706 Board, Since the mode of operation of HDMI is changed from YcbCr 4:2:2 to Ycbcr 4:4:4. Since i am new to video processing. Please help.
Rajesh khanna
02-21-2020 03:24 AM
We are able to resolve the issue in ZC706, problem is we need to use clock as 148.5 MHZ for 1920 X 1080 @ 60 Hz Resolution.
Rajesh khanna
02-19-2020 10:14 PM
Hello @rajeshkhanna
I believe you are mentioning design provided at https://forums.xilinx.com/t5/Video/Video-Series-19-Using-the-On-Board-HDMI-on-ZC702-Vivado-design/td-p/914989 . Please confirm.
I will reproduce this issue and let you know details.
02-19-2020 11:06 PM
Yes you are right we tried with the same design modified the ucf and settings corresponding to ZC706 but the design is not working.
Rajesh khanna
02-21-2020 12:51 AM
Hello @rajeshkhanna
There is limitation with ZC702 HDMI Codec innterface. Only 16-bit of Video Data lanes are connected for ADV7511 IC. So, ADV7511 supports 1080P 60Hz, YCbCr 4:2:2 encoding via 16-bit input data mapping on ZC702 board.
While YUV4:4:4 data type requires 24 bit Video data lines.
02-21-2020 12:58 AM
HI Bhusan,
Thanks for you reply.
The codec you are showing corresponding to ZC702. I having ZC706 the codec shown as per user guide is as follows. I am able to generate the bit file and able to detect the monitor. i am not able to send video to display. display resolution is 1920 x 1080 - 60 Hz.
02-21-2020 03:24 AM
Rajesh khanna
