uuoo93
ZCU102, ‘MIPI CSI-2 RX subsystem IP example design’ problems on vivado 2018.2
Hello. I am working on Zynq UltraScale+ ZCU102 Evaluation Board and Vivado HLx system suite version 2018.2.(Window O.S) I was trying to open ‘MIPI CSI-2 Rx subsystem IP example design’ and it was successful until ‘Block Design’ was generated as shown in Figure 1 below. figure 1.png
<Figure 1>
However, I faced the problem when trying ‘Run Synthesis’ as shown in Figure 2 below.
<Figure 2>
How can I solve this problem?
florentw
Hi @uuoo93,
This is a path length issue. You might want to generate the example design at the root directory of your drive.
You can also apply the same steps as mentioned in AR#70328 (adapt it for MIPI).
Note that the path lenght should be reduced in the example design for 2018.3
Hope that helps,
Florent
florentw
Hi @uuoo93,
Hope that helps,
Florent
