08-19-2020 01:31 AM
I use Petalinux to build the system run on ZCU102 board. I have played .webm video format sucessfully, but when I try to play a .mp4 video format I met an error:
The error is shown below:
root@xilinx-zcu102-2020_1:~/honglc_samples/segmentation# gst-launch-1.0 filesrc location=./video/traffic.mp4 ! qtdemux name=demux demux.video_0 ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1
Setting pipeline to PAUSED ...
[2020-08-19 05:02:20.494530490] [omx_core.cpp:181] [OMX_GetHandle] Couldnt allocate dma allocator (tried using /dev/allegroDecodeIP)
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0: Could not initialize supporting library.
Additional debug info:
../../../../git/gst-libs/gst/video/gstvideodecoder.c(2614): gst_video_decoder_change_state (): /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0:
Failed to open decoder
Setting pipeline to NULL ...
Freeing pipeline ...
I have installed the H264 enc/dec libaries, but can not fix the error:
root@xilinx-zcu102-2020_1:~/honglc_samples/segmentation# gst-inspect-1.0 | grep h264
typefindfunctions: video/x-h264: h264, x264, 264
rtp: rtph264depay: RTP H264 depayloader
rtp: rtph264pay: RTP H264 payloader
uvch264: uvch264mjpgdemux: UVC H264 MJPG Demuxer
uvch264: uvch264src: UVC H264 Source
omx: omxh264enc: OpenMAX H.264 Video Encoder
omx: omxh264dec: OpenMAX H.264 Video Decoder
videoparsersbad: h264parse: H.264 parser
Could you help me on this?
08-26-2020 07:21 AM
Hi @conghong
The ZCU102 does not include the Video Codec Unit (VCU) which allows to encode/decode H264/H265 video files. Thus there is no HW to do the decoding. I guess this is the issue you are facing.
You need to use a board which has a ZU-EV part as the ZCU104 or ZCU106.
08-26-2020 02:45 PM - edited 08-26-2020 02:45 PM
Hi @conghong
Would you share the followings to investigate the route cause ?
- Boot log message
=> Make sure whether some IPs are properly initialized or not.
- debug log with gst-debug-level
=> Run the following command to output debug message. Make sure how to launch gstreamer's pipeline.
gst-launch-1.0 --gst-debug-level=3 filesrc location=./video/traffic.mp4 ! qtdemux name=demux demux.video_0 ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1
- make sure file information of "traffic.mp4" to set properly caps. on gstreamer's pipeline. (=> I guess it's the route cause.)
=> Run the following to make sure file information by ffmpeg
ffmpeg -i traffic.mp4
Best regards,
08-27-2020 08:31 PM
Thank you for your replying, I have fixed this error.
The solution is we need to install the avdec_h264 plugin for GStreamer.
By the way in the file petalinux_project_dir/project-spec/meta-user/conf; we need to add following lines:
PACKAGECONFIG_append_pn-gstreamer1.0-plugins-ugly = " x264"
Thanks all.
08-27-2020 09:02 PM
Hi @conghong
Thank you for sharing your solution.
Oh, I forgot the device on ZCU102 is ZCU9EG. Not EV series.
So, you can't use omxh264dec...
Yes. You need software decoder for H.264. So, you need to add "x264" (software decoder element) on "gstreamer1.0-plugins-ugly".
I hope it helps.
Best regards,
02-15-2021 09:42 PM
I have the same problem and I need to add the avdec_h264 plugin. However, when I added PACKAGECONFIG_append_pn-gstreamer1.0-plugins-ugly = " x264" to the path:
petalinux_project_dir/project-spec/meta-user/conf/layer.conf
After building the petalinux project, there was still no avdec_h264 plugin.
I use petalinux2020.1 and ZCU104. Is there something I forgot when I added this plugin?
