calcius
ZCU104 Display Port Baremetal Vitis 2019.2
I am trying to get 4K video output on ZynqMP device, we start testing it with Single sensor reference platform on ZCU104 and we test both HDMI and Display port outputs.
Unfortunately I am not an expert in linux, gstreamer etc and it is very dificult to start with this complex architecture and at this moment I am working on a baremetal solution.
I use Vitis 2019.2 and the Single Sensor .XSA platform to test dpdma video example.
1. I check my BSP and psu_dp driver is dppsu instead of avbuf.
2. Import the example xdpdma_video_example from dpdma driver
3. ZCU104 Display port use two lanes and I not modify anithing.
4. I show the terminal output and all work fine but I show two problems:
- At 1920x1080p60 my monitor going to sleep and my monitor (HP E231) support this resolution.
- I modify the example to lower resolution 1280x720p60 and 800x600p60 and monitor detect the signal and parameters but the image allways was black.
This is the output from the serial terminal:
Successfully ran DPDMA Video Example Test
HPD event .......... ! Disconnected.
.......... HPD event
HPD event .......... ! Connected.
Lane count = 2
Link rate = 6
Starting Training...
! Training succeeded.
DONE!
Lane count = 2
Link rate = 6
DONE!
HPD pulse ..........
! Re-training required.
Lane count = 2
Link rate = 6
DONE!
.......... HPD pulse
watari
calcius
@watari Thanks for the info, this could be the problem at 1080p, but at lower resolutions why I see all the image black?
Best regards
watari
Hi @calcius
Can you make sure HDP signal and/or DPCD value ?
If yes, you can find correctly the route cause.
I guess your monitor doesn't have enough capability to communicate and display video stream between them.
Best regards,
