Hrishikesh
ZCU104 Pynq Base Overlay
I am working on Creating a HDMI Design using Zynq MPSoC 7EV device using Vivado 2020.1 using VDMA IP.
I found ZCU104 Pynq Base overly which uses VDMA, so i decided to follow the same implementation method.
I am not able to understand why are HLS modules, Pixel Unpack and Colour Convert are used.
I wanted to know will the design work without using them. Cant I only use VDMA, can someone briefly explain what those HLS modules are doing.
Thanks & Regards
N Hrishikesh Prabhu
Tags (3)
