sberner66
ZCU104 -- Use HDMI connectors for general purpose data link between two boards ?
I want to use the HDMI connectors to connect two ZCU104 boards and transfer data packets between them. I connected an aurora_64b66 module to one of the HDMI lanes, ref clk is HDMI_RX_CLK = 125 MHz. As a start, I tried a loopback, HDMI TX connector connected to HDMI RX connector of the same board.
I have an unstable loopback link at 0.6 Gbit/sec with a LONG cable, means channel_up of aurora module high may be 80% of the time. All other configurations, higher or lower rate, shorter cable, don't work.
I suspect the problem are the signal conditioning chips, SN65DP159RGZ and TMDS181IRGZT, which most likely depend on the HDMI protocol.
Questions:
1) Is this idea feasible ?
2) When using the signal conditioning chips SN65DP159RGZ and TMDS181IRGZT in redriver mode, is there still any depency on the HDMI protocol or do they work for any high speed serial data ?
3) Is there any sample code for reprogramming those chips vis I2C ?
4) Do I have to reprogram those chips ? I read in the data sheet that redriver mode is automatically selected if the rate is low.
Tags (2)
sberner66
SUMMARY:
To get the link working the following steps are necessary.
1) Instantiate an aurora8b10b module, connect the lane(s) to the HDMI pair(s), choose ref clk 0 in the aurora GUI which connects the clk from the 8T49N241 PLL chip. aurora64b66b may work to, but haven't retried.
2) Program the 8T49N241 as a synthesizer generating 148.5 MHz as shown above. Adjust the rate of the aurora module in the GUI such that 148.5MHz is a legal reference clk frequency, select this ref clk frequency. For example, the lowest possible rate it 4*148.5 MHz
3) Program the driver chip and receiver chip for redriver mode as shown above because in retiming mode the operation of these chips relies on a valid HDMI signal
sberner66
One obvious mistake was to use the aurora-64b66b module. HDMI relies on 8b10b coding and using the aurora-8b10b module makes more sense.
After replacing the 64b66b module by the 8b10b module, it works much better, but there are still problems.
Having an HDMI loopback, 5 feet cable, rate = 1.25 Gbps, ref clk = 125 MHz, the channel goes down randomly every few msec for a duration of a few usec.
A loopback with rate = 0.5 Gbps, ref_clk = 125 MHz works better, but still not error free.
sberner66
As suspected earlier, forcing the signal conditioning chips DP159 and TMDS181 into redriver mode by I2C commands solves the problem of the loopback errors mentioned in previous reply
Steps to do:
1) Instantiate an AXI IIC Bus Interface
2) reprogram the signal conditioning chips
//set redriver mode
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0xbc; //dev addr
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x0a; //subaddr
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x00; //data
*((u32 *) (AXI_I2C_BASEADDR + CR)) = 0x0d; //master, tx, en
while(!(*((u32 *) (AXI_I2C_BASEADDR + SR)) & 0x80));
//*((u32 *) (AXI_I2C_BASEADDR + SR)) = 0x40;
xil_printf("DP159 redriver mode set\n\r");
usleep(10000);
*((u32 *) (AXI_I2C_BASEADDR + CR)) = 0x0;
//power down chip
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x09; //subaddr
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x08; //data
//*((u32 *) (AXI_I2C_BASEADDR + ISR)) = 0x40;
xil_printf("DP159 powered down\n\r");
usleep(10000);
//power up chip
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0;//0x08; //data
while(!(*((u32 *) (AXI_I2C_BASEADDR + ISR)) & 0x40));
xil_printf("DP159 powered up\n\r");
usleep(10000);
//set redriver mode
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0xb8; //dev addr
xil_printf("TMDS181 redriver mode set\n\r");
usleep(10000);
//power down chip
xil_printf("TMDS181 powered down\n\r");
usleep(10000);
//power up chip
xil_printf("TMDS181 powered up\n\r");
usleep(10000);
toshas
Thanks for sharing!
sberner66
I also had to program the 8T49N241 PLL chip working as a synthesiser to have a local reference clock for the aurora module. I took the configuration of the chip from
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/v_hdmirxss/examples/xhdmi_example/idt_8t49n24x.h
which programs the chip to generate an output clk frequency of 148.5 MHz.
static const u8 IDT_8T49N24x_Config_Syn[] = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xEF, 0x00, 0x03, 0x00, 0x31, 0x00,
0x04, 0x89, 0x00, 0x00, 0x01, 0x00, 0x63, 0xC6, 0x07, 0x00, 0x00, 0x77,
0x6D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x01,
0x3F, 0x00, 0x28, 0x00, 0x1A, 0xCC, 0xCD, 0x00, 0x01, 0x00, 0x00, 0xD0,
0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x0C, 0x00, 0x00,
0x00, 0x44, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B,
0x00, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x89, 0x0A, 0x2B, 0x20,
0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
*((u32 *) (AXI_I2C_BASEADDR + CR)) = 0x05;
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x100|T49N241_BASE_ADDR;
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0; //offset MSB
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0; //offset LSB
u32 i;
for(i=0; i<sizeof(IDT_8T49N24x_Config_Syn)-1; i++)
while(*((u32 *) (AXI_I2C_BASEADDR + SR)) & 0x10); //while tx fifo full
//*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = IDT_8T49N24x_Config_JA[i];
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = IDT_8T49N24x_Config_Syn[i];
//*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x200|IDT_8T49N24x_Config_JA[sizeof(IDT_8T49N24x_Config_JA)-1];
*((u32 *) (AXI_I2C_BASEADDR + TX_FIFO)) = 0x200|IDT_8T49N24x_Config_Syn[sizeof(IDT_8T49N24x_Config_JA)-1];
xil_printf("8T49N241 full config\n\r");
NOTE:
For an unknown reason before being able to program the chip I have to do some other i2c ops. In my case I am running a loop scanning for i2c slaves. Otherwise the  8T49N241 is unresponsive. Why ????
sberner66
SUMMARY:
How did you programed to 8T49N241 . I am also trying to get HDMI clock but i am not getting so please help me to get clock.
Hi sir how did you buid SDK project to take these files to program 8T49N24*. Please share if you have build project of sdk.
Thanks in advanced,
Rahul
7506673942,
kumar090192@gmail.com
sberner66
Please see attached sdk project. The intention of this project was to transfer packets between HDMI  and a shared buffer between a53/r5 by DMA. The r5 initializes the HDMI, DMA, and manages the packet transfers. Important file is HDMA_init.c.
