ZCU106: TRD for VCU
I took the example project from
http://www.wiki.xilinx.com/Zynq%20UltraScale%20MPSoC%20VCU%20TRD%202018.1%20-%20Design%20Module%204?responseToken=0d2781738bdcd858a1b3ed4416948c3c4
this project runs well but when I check the CPU load (using TOP), I found that in 4K, 60Hz the load is around 88% (TOP tool only shows CPU usage for one core) for HEVC_HIGH.
I would like to know why the CPU usage is high?
Thanking you
Best regards
Hi @msh,
You should be able to do some profiling on the CPU to check why the CPU usage is so high. It might depends on your source/sink if writing from a file or to network
I just use the MIPI camera just like in the project.
Then use the encoder and decoder for the stream to display in HDMI without saving the stream as it explained in the example with the .cfg file. Not sure what software is doing though I just took the image file.
% vcu_gst_app /media/card/config/1-4kp60/Display/Single_4kp60_HEVC_HIGH.cfg
How can I do profiling?
Best regards
Hi @msh
I think you can use this:
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8BMPSoC+Graphics-+GPU+Profiling+using+ARM+Streamline+performance+analyzer
And adapt it from your project
Hi @msh,
Thanks and Regards,
