bilal5330
ZCU106 VCU TRD 2019.1 SDI Tx example not working
I am using ZCU106 VCU TRD 2019.1 examples as it is, i.e. without any compilation or building.
I am able to sucessfully run HDMI Tx example and it can read a TS file from SD Card or USB, decoding it and displaying over monitor (as shown in the image).
However when I run SDI Tx example using same TS file, it gives me error "ERROR: vgst_config_options() failed, error code "VLIB DRM Plane Not Found".
I tried to run the SDI Tx through stream input as well, but it failed too, giving following error "ERROR: vgst_start_pipeline() failed error code "state change failed".
I was thinking if it had been an input file encoding issue, why did it run in case of HDMI.
I am just passing my own TS file name,  input resolution, and UDP IP information in .cfg files provided in the original TRD, but nothing works.
However I am able to see output monitor tuned up when I run the following command.
$ xmodetest -M xlnx -s 36:1920x1080-60@XV20  -w 36:sdi_mode:2 -w 36:sdi_data_stream:2 -w 36:is_frac:0 &
I am using an SDI to HDMI convertor to get SDI output from ZCU106.
Any guidance and suggestions are highly appreciated as I am a beginner working with VCU TRD.
Thanks in advance.
Bilal
Tags (5)
watari
Hi @bilal5330
Could you share log file or zoom-up two kind of console's picture ?
It is hard to make sure console messages for me.
Best regards
bilal5330
Thanks watari,
I have attached the full log in attachment.
Here is the last excerpt from that log in the bottom.
Note: I am using "inpsdc.cfg" which is a copy of .cfg file provided in TRD for SDI-Tx example. (I have attached it as well).
I am only replacing my TS file name, FPS and resolution information in it.
Thank you so much again,
Bilal
root@zcu106_vcu_trd:~# xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
net.core.rmem_default = 60000000
net.core.rmem_max = 60000000
net.core.wmem_default = 60000000
net.core.wmem_max = 60000000
setting mode 3840x2160-60Hz@XV20 on connectors 36, crtc 34
[ 40.254757] xlnx-sdi-tx a0040000.v_smpte_uhdsdi_tx_ss: AXI-4 Stream Underflow error
root@zcu106_vcu_trd:~# cd /media/card/bin
root@zcu106_vcu_trd:/media/card/bin# ls
inpsdc.cfg vcu_gst_app xmedia-ctl xmodetest
root@zcu106_vcu_trd:/media/card/bin# vcu_gst_app inpsdc.cfg
ERROR: vgst_init() failed error code -75 :: "VLIB No media source Available"
Get "VLIB No media source Available" error in Tx only design, can be ignored!!!
/*************************Pipeline Information Start*************************/
Pipeline Info : On
Fps Info : On
APM Info : On
Output goes on : SDI
Frame rate : 50
Number of Source is : 1
Use case is to : Display
Device Type : TPG
Format : NV12
Width : 1920
Height : 1080
Raw : False
Accelerator flag : False
Enable_scd flag : False
Src Type : File Src
URI : file:///media/card/aeroplane.ts
/*************************Pipeline Information End*************************/
watari
Hi @bilal5330
I guess it seems clock source issue from boot log file.
But I don't have any idea to resolve this issue now.
Would you make sure clock source and AXI4Streaming clock on SDI Tx ?
aoifem
Hi @bilal5330
Do you have any update on this?
Aoife
