ZCU106 video output to monitor and save to filesystem at the same time
Hi all,
I want to receive video from udp stream via vlc player. I found pipeline related to this request. It works fine.
gst-launch-1.0 udpsrc port=1234 ! tsdemux name=tsdemux ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1
And I want to save video to filesystem from udp stream. I found pipeline related to this request too. It works fine too.
gst-launch-1.0 udpsrc port=1234 buffer-size=90000000 ! filesink location=output.mp4
My goal is to do requests above simultaneously. I mean, I want to save my streaming video to filesystem while mirroring to monitor at the same time.
How can I do that?
Can you help me?
Additionally, how can I improve my pipelines in terms of performance? Any advices?
Hello @hakann ,
You should look into adding the 'tee' function for your video pipeline to combine the two commands.
Hello @hakann ,
Thats what I was thinking too. I use it in scripts to write the output of something to the console and in a file at the sametime. Now, to make it work in this context im not sure :S
@simon.beaudoin
gst-launch-1.0 udpsrc port=1234 buffer-size=90000000 ! tee name=t t. ! queue !gst-launch-1.0 udpsrc port=1234 ! tsdemux name=tsdemux ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1 t. ! queue ! filesink location=output.mp4
By the way, we can be done by mirroring from HDMI TX output like this : gst-launch-1.0 udpsrc port=1234 ! tsdemux name=tsdemux ! h264parse ! tee name=t ! queue ! omxh264dec ! queue max-size-bytes=0 ! kmssink bus-id=a0070000.v_mix fullscreen-overlay=1 t. ! queue ! filesink location=out.mp4
Thanks a lot for your answers.
