Zynq Ultrascale MPSoc VCU TRD 2018.1 Image File Missing
I want to implement Zynq Ultrascale MPSoc VCU TRD 2018.1 Design Module-2 application on zcu106. In Directory Structure and Package Content it says "The TRD package is released with the source code, Vivado project, petalinux project, and SD card image that enables you to run the demonstration." When I tried to write image to SD Card(via Win32 Disk Imager) and downloaded rdf0428-zcu106-vcu-trd-2018-1 zip file, however there is no image file in image folder. I don't know what should I do. I could'nt find anything the image file on the internet. Where can I get it?
Thanks in advance.
Hi @silat14
The image file is a term to talk about the file on which the linux kernel is, ie read kernel image.
This is included in the BOOT.BIN file. This is the file that you need to copy to the SD card.
Hope that clarifies,
Hi @silat14
Hi @silat14
Do you have any update on this? Is everything clear for you?
Thanks and Regards,
