jan_ch
Zynq7000 HDMI OUT video design
Hello, I will be preparing the project for a custom board with Zynq-7000 with ADV7513. The design must be able to handle Linux OS GUI interface. I am looking for advice and maybe some tutorials because I would like to choose the best way to achieve that. I saw three main ways:
- using VDMA and Analog Devices IPcores
- using VDMA and Xilinx IP cores such as AXI stream to video out, timing controller, etc
- I read about using Xilinx Frame buffers and IP cores for it.
Which way would you recommend and is there a complex tutorial with hardware and Linux information for HDMI out?
Best regards,
JAN
watari
Professor
Professor
tedbooth
I don't know of a tutorial that covers all of what you are looking for but the ZC702 TRD design might be a good place to start:
https://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/2015_4/ug925-zynq-zc702-base-trd.pdf
If you are just getting started doing video on Xilinx parts, I recommend looking at the following Video Series:
https://forums.xilinx.com/t5/Video/Xilinx-Video-Series/td-p/849583
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
watari
Professor
Professor
florentw
Hi @jan_ch
Do you have any updates on this topic? Were @tedbooth and @watari 's replies enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
