axis4-stream problem
Hello every body
it's my first time to poste something here...
I have a problem in my block design that is acquiring data from a FLIR (HDMI) camera and then sending it back to a VGA monitor.
In the following example, it work when I implement it on FPGA ZYBO board, but I want to convert the frame data to AXis-stream data (to be the input of an HLS IP) but after the implementatio it doen't work, the bistream is generated but I get a black screen
I respected the resolution and the timing but I don't now why it doen't work?
Please help
This is my design with the axis4-stream
Hi @azerty,
If everything is clear for you, please kindly close the topic by marking a reply as accepted solution.
Thanks and Regards,
Hi @azerty,
Your topic is in SDSoC, are you using SDSoC for your design? It might be better in the video board.
Then, did you use any ILA on the AXI4S interface?
I would check the overflow and underflow outputs from the Video In to AXI4S and AXI4S to Video Out.
I would also connect all the clken unconnected to one.
Hi, thank you for your reply
I'm not using SDSoc for my design, I'm  just using Vivado HLS and Vivado DesignSuit, I can't use any more tool (this is my project and I want to use only Vivado). Also I'm not using any ILA (just axis_stream interfaces)
I think that the probleme is some additionals pixels because when I use the design without the axis4_stream, I get my image and some black pixels beside.
Hi @azerty,
Yes, the AXI4S to video out will need the input data to correspond to the timing. So if it does not match, you won't have any outputs
Hi @azerty,
Thanks and Regards,
