black box addFile
I've to import in system generator a "big" black box.
This block is composed by a lot of vhdl subfiles and I don't know the right comilation order (but I can reconstruct it by ISE).
There is a way to add all the vhdl files quickly (for example using wildcards) ?
You have to modify the _config.m file to add all the files.
These will then be added to the ISE project approriately, so the order isn't necessarily important for synthesis.
I think iSim will also figure out the compilation order, but you might need to put them in the correct order if you are trying to simulation with ModelSim.
Chris
Versal ACAP: AI Engines | Embedded SW Support
