jothiadithya
capturing slow
I have system with tpg. The frame capture is very  slow. what could be the issue
root@plnx:~# yavta -c3 -n3 -s 1920x1080 -f RGB24 -Ft1.raw /dev/video0
Device /dev/video0 opened.
Device `vcap_tp0 output 0' on `platform:vcap_tp0:0' is a video output (without mplanes) device.
Video format set: RGB24 (33424752) 1920x1080 field none, 1 planes:
* Stride 5760, buffer size 6220800
Video format: RGB24 (33424752) 1920x1080 field none, 1 planes:
3 buffers requested.
length: 1 offset: 3202890280 timestamp type/source:[ 409.804971] xilinx-vtc 43c20000.v_tc: Failed to set clk rate: 4767200, actual rate: 71500000
mono/EoF
Buffer 0/0 mapped at address 0xb68aa000.
length: 1 offset: 3202890280 timestamp type/source: mono/EoF
Buffer 1/0 mapped at address 0xb62bb000.
Buffer 2/0 mapped at address 0xb5ccc000.
0 (0) [-] none 0 0 B 444.411880 444.411929 0.029 fps ts mono/EoF
1 (1) [-] none 1 0 B 461.747151 461.747196 0.058 fps ts mono/EoF
2 (2) [-] none 2 0 B 479.082424 479.082472 0.058 fps ts mono/EoF
Captured 3 frames in 69.341153 seconds (0.043264 fps, 0.000000 B/s).
3 buffers released.
watari
Hi @jothiadithya
Would you try to change storage from SD card to ram disk (ex. /tmp) or faster storage to investigate route cause ?
florentw
Hi @jothiadithya
This could be a hint:
Do you have a programable clock? You would need to investigate why you get this message.
Also, are you sure you have enough bandwidth to access the memory?
watari
Hi @jothiadithya
What kind of storage do you use ?
Is it an enough performance to record this streaming ?
aoifem
Hi @jothiadithya
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
jothiadithya
SD card
florentw
Hi @jothiadithya
Do you really need help here?
There was 4 questions and you just replied to 1 really quickly
jothiadithya
thanks for the response.
1. I do not really know how to measure the band width.
2. I haven't any idea why Vtc shows error.
i do really need solution
florentw
Hi @jothiadithya
Can you share what your HW looks like?
jothiadithya
I am using Zynq 7020
tpg -> frmbuf-wr -> ddr
I can post the block diagram tomorrow since I left for the day
watari
Hi @jothiadithya
jothiadithya
Yes. That was the issue. Thanks
