ekrats
dp_rx_subsystem dp12rxss examples
The standalone example dp12rxss corresponding to pg233-displayport-rx-subsystem, is there any dp12rxss linux driver ?
Best regards.
florentw
Hi @ekrats
Yes you might need to write your own drivers.
I know one customer who ported the driver to the linux userspace and made it work. But this flow is not supported by Xilinx.
Another suggestion is to have a microblaze in the PL running with the baremetal driver
Florent
florentw
Hi @ekrats
No there are not linux drivers for the Displayport RX/TX subsystems and Displayport 1.4 RX/TX subsystems.
The only linux driver available is for the Displayport hard controller of the ZynqMPSoC.
Florent
ekrats
Hi, @florentw
How to make this example run on linux OS, do I need to write code to configure IP and DP159 according to dp12rxss example?
Best regards.
florentw
Hi @ekrats
Florent
ekrats
Hi, @florentw
thank you for your reply.
Where is the post, this is what I want.
Best regards.
florentw
This is not through the forums
Florent
ekrats
Hi, @florentw
Which method do you prefer?1、ported the driver to the linux userspace. 2、microblaze in the PL running with the baremetal driver.
florentw
Hi @ekrats
Only the baremetal drivers are supported so the second option is recommended
Florent
watari
Professor
Professor
Hi @ekrats
If you try porting or developing kernel driver for DP Rx, it would be helpful to refer the following URL.
Because you must describe V4L2 driver, if you want to use DP Rx on linux.
https://www.kernel.org/doc/html/v5.4/media/uapi/v4l/extended-controls.html
I hope this will help.
Best regards,
