gateway in/ out
I have a problem with my model.......
when i remove the gateway out...my model is generating  but when i added them i can't generate my model.
where's the problem ???
Are you getting an error message?  What is your compilation target?  What else is in your model besides a gateway out?
well am doing hardware co-simulation using spartan 3E starter....
i am only using adders and multipliers in my model.......several blocks of course...
thats it, when i remove the gateway out, the model is generated.when i add it it won't
It will be very hard to diagnose your problem without more information.  The best thing to do is to open a support case with Xilinx here:
http://support.xilinx.com/support/clearexpress/websupport.htm
