help needed regarding use of external RAM
hi
I want to store my data  in external RAM and than subsequently calling it from external RAM for processing.
I want  to ask if there are any tutorials or documentation available for this in system generator(preferably) or in any other way.
              SALMAN
In System Generator 13.2, you can use the VDMA block, which gives acces to external memory for the ML605, SP601 and SP605 boards.
Chris
Versal ACAP: AI Engines | Embedded SW Support
