i2s transmitter and receiver in Vivado
I am using "create block digrams "in vivado for I2s transmitter and receiver. But i dont find any option to make it as slave. Does Both the transmitter & receiver get created as master only? How can i convert it to slave. Coz when i create the block diagram, the resultant wrapper creates "read- only "RTL files wherein i can't change the clock ports as inputs (i.e as slave)
Hello @monali
I2S TX/RX IP support only Master mode. Slave mode is not supported as per mentioned in unsupported features of PG308.
Thank you
Kunal
