dehaze
image enhancement v8.0 issues
I am using xilinx image enhancement v8.0 in my porjects(Vivado 2018.3). Everything is OK except setting register 0x0020 via AXI interface.
If I am using no AXI-lite Register Interface mode,the  image enhancement works fine.
Because I needed to change the value of enhance strength,So I add AXI-lite Register Interface mode. Then I can change the  value Halo suppression,Anti-Alias,Image Edge Enhancement  via AXI interface in SDK,except setting register 0x0020 (acvtive size),register 0x0020 always 0. Even I use xil_out32 to change register 0x0020,the register is still 0.
why.
florentw
Hi @dehaze
First note that the image enhancement v8.0  is a discontinued IP and there is no official support from Xilinx.
With that say, you probably forgot to set REG_UPDATE in the control register after changing the configuration:
Florent
florentw
Hi @dehaze
Florent
aoifem
Hi @dehaze
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
