andresmunoz
load values and plot using bertool of simulink
I'm trying to get the BER-Eb/No curve based on the variation of channel noise power level. Is there any way to load all the values i need as parameter in the noise power level and then export the BER information to "BERTOOL" of simulink ?
I tried the way simulink do, but it didn't work
thnx!!!!!
balkris
I think best way is to export the parameter value using the toworksapce block. you can also use file handlingi.e. fopen, fwrite, fread commend to store the value and then plot the BER curve in Simulink
Thanks and Regards
Balkrishan
