mipi-csi2-rx subsystem license expire for vivado2018.3
Dear,
Why my all previous Vivado2018.3 projects (event previous Boot.bin) could not work again even I apply new license (120 days) of mipi-csi2-rx subsystem recently?
I also try to do "Reset Output Products" and re-synthesis...bitstream (all pass), but they all could not work again for my ZCU102 FPGA board?
Any comments?
Thanks for reply.
Sorry, It is HW issue. Thanks a lot.
karnanl
Hello p.ching.kuang@gmail.com
1. I am not sure if this is a license issue, since you can synthesis and generate bitstream without any issue.
    Could you please check if this is not a board issue ?
    ( If previous boot.bin does not work, I believe this is HW related issue )
2. BTW, since 2020.1, Vivado has included MIPI CSI-2 TX/RX Subsystem IP without any extra cost ( It does not requires a license anymore )
    If you can ensure that this is not HW/board issue, but the issue persist, you could also migrate to 2020.1 (or newer Vivado version).
Kind regards
Leo
Versal Blogs
Thanks for reply.
