my custom image process ip can't stop running
I have customized an image processing IP that has two input channels and one output channel, like this:
The foreground and background images entered are two axis channels. I use two vdmas for image input, and I output directly to one of the vdma inputs. However, when I write two images directly into the vdma, the write operation will not stop, so I can't read the vdma to get the processed image.
I am using the pynq system. When running vdma.write, it will continue to run in this line, and will not stop without error. Attachment is my ip block design, help out.
Tags (2)
Hi 1028271706@qq.com
As mentioned in a different topic, you might need to investigate on the HW using an ILA. It might be that your IP never completes to process the frame and it might just be because at the input, the frames do not complete.
Pynq is great to do high level when you know that IPs are working. I am not sure if it is the best way to test an IP in HW.
Florent
Who generate like SOF, EOF for VDMA ?
I guess nobody generate it.
Best regards,
Hi. Your hardware looks good. You can get better performance by enabling HP1 and HP2 and connect each of those MM ports to one of them. But it must work. Problem must be from your software or your custom module. If you didn't work with VDMA, recommend you to have a simple design with it first. Also try to use chip scope to have better sense of what's going on. If you already checked all of them, then it must be from your custom module.
the customized ip is made by vivado hls, it is very simply:
void Circle_pratial_process(AXI_STREAM& Foreground, AXI_STREAM& Background, AXI_STREAM& Output)
#pragma HLS INTERFACE axis port = Foreground bundle = INPUT_STREAM
#pragma HLS INTERFACE axis port = Background bundle = INPUT_STREAM
#pragma HLS INTERFACE axis port = Output bundle = OUTPUT_STREAM
#pragma HLS INTERFACE s_axilite port = return
GRAY_IMG foreg, backg, difference;
AXIvideo2Mat(Foreground, foreg);
AXIvideo2Mat(Background, backg);
//background - foreground
hls::AbsDiff(foreg, backg, difference);
Mat2AXIvideo(difference, Output);
and it works well in testbench, i dont know why it has problem in the ip.
Florent
Test it by running debug core to find out what's going on exactly. I think it must be best way for your case.
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
