one TPG drive multiple video stream outputs not synchronized
    On my custom Kintex 7 board,  I use one TPG to generate one 1080p@60 video streams,  and then feed it to two AXI4-Stream to Video Out, which are connected to 2 ADV7511 chip. The video out is ok, but the two TVs are not frame-synchronized (one TV  lost 1 frame sometimes), even switch these TVs's connections this phenomenon still not change.
The block design uses onboard 200MHz  differential clock to feed  into Clock Wizard to get 148.5MHz.  I have read PG235, it recommended to use Si5324 to clean up pixel clock for HDMI Transmitter Subsystem
example. However I'm not use this IP but use ADV7511.
Does this design must have external oscillator? Any other suggestion is appreciate.
Best Regards
Hi @xxhc417s
I think you should look at the ADV7511. This might be where the delay is added.
You might want to discuss with Analogue Devices to check if they have any option to synchronize multiples.
I do not think just having the sync/data signals synchronized will be enough.
Florent
Hello @xxhc417s
I believe you need to use AXI4-Stream Switch after Video Test Pattern Generator (VTPG) to implement your design. You can find more information on AXI4-Stream Switch in PG085.
Your setup will be as follows:
VTPG >> AXI4-Stream Switch >> two processing paths (each one will have indenpendent AXI4-Stream to Video Out) >> Two ADV7511 chip
Bhushan
hi,
 I am sorry for the incorrect description. The Block Design has only one axis video stream, and one axi4-stream video out. Pins of the two adv7511 chips  are connected to the same net internally, i.e. de_0 connects  to de_1, hsync_0 connects to hysnc_1..., so they should have the same data and clock.
Best Regards
Hello @xxhc417s
Is it possible for you to share block diagram of your setup?
Vivado tool version?
Bhushan
Thanks for your reply.
The monitor have four HDMI inputs.  TPG  was setup to generate moving box. When the input frames are not synchronized, the boundary of boxes are not aligned.
Hi @xxhc417s
Florent
Hi @xxhc417s
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Aoife
