problem with Video On‐Screen Display v6.0 Bit Accurate C Model
We installed OSD bit accurate C model for 64-bit Linux platform and we are getting following Error
libIp_v_osd_v6_0_bitacc_cmodel.so: file not recognized: File format not recognized
Thanks in advance
Hi shantaramjagtap1994@ ,
Note that the OSD IP is a discuntinued IP. Xilinx will not provide any support on this. The recommendation is to use the Video Mixer IP as a replacement.
However, we will not prevent you of using this. I would recommend you that you followed the installation steps:
For Linux, make sure the following files are in a directory in the $LD_LIBRARY_PATH
environment variable:
• libIp_v_osd_v6_0_bitacc_cmodel.so
And you are using the gcc versions mentioned in the documentation.
Would you make sure file format by using following command on Linux ?
$ file libIp_v_osd_v6_0_bitacc_cmodel.so
I guess it seems platform issue.
Thanks for reply,
I found C model in below hierarchy
.......\project_1.srcs\sources_1\ip\v_osd_0\cmodel\v_osd_v6_0_bitacc_cmodel_lin64.zip
According to PG010_v_osd_0.pdf  On‐Screen Display v6.0 Bit Accurate C Model for  32-bit Linux and 64-bit Linux platforms but it generates v_osd_v6_0_bitacc_cmodel_lin64.zip Where I can find for lin32.
Thanks for reply,
Our demo application requires Text and image layers. video mixer does not support for text generation. Thats why we require IP which support both, i.e.OSD.
Do you have any suggestion about other IP which meet our requirement.
We are using gcc version 4.8.4 and documentation recommended 4.1.6
Will this cause any problem?
HI shantaramjagtap1994@ ,
No there is no other IP for text generation.
Yes the gcc version might be the issue
