pierlum
Voyager
Voyager
"Exec format error" running compiled vcu app ctrlsw_decoder
Hello I downladed code for VCU control software sample app. I compiled ctrlsw_decoder using ""make" command. The generated ctrlsw_decoder executable dosn't work when I run it on in petalinux. When I try to run the error is "Exec format error".
I think the reason is because it was not compiled for the correct architecture.
What should I do?
pierlum
Voyager
Voyager
Hi @watari ,
I solved the problem. I work with 2019.2 and the correct code must be downloaded from https://github.com/Xilinx/vcu-ctrl-sw/tree/release-2019.2 . Pg252 v1.2 at page 224 gives this link https://github.com/Xilinx/vcu-ctrl-sw . But it refers to an older version of the code of the sample app. I think that in the next version of pg252 it must be updated.
Thank you.
watari
Hi @pierlum
Would you make sure an architecture of binary file with "file" command ?
ex.)
$ file abc-program
I guess, you didn't use proper cross-compiler...
Best regards,
pierlum
Voyager
Voyager
HI @watari ,
this is the output of "file ctrlsw_decoder"
root@uz7evcc_vcu-only_v2019:/media/emmc# file ctrlsw_decoder
ctrlsw_decoder: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 3.2.0, BuildID[sha1]=4a8d7cf29c1574de7196cde0f82874f0853f3d9f, not stripped
Yes as you suggested it seems to be a cross-compiling problem. I have to edit makefile to make this executable work on Zynq? Thank you very much.
pierlum
Voyager
Voyager
Hi @watari ,
I modified Makefile in this way and I installed "gcc-aarch64-linux-gnu" and "g++-aarch64-linux-gnu" and now the executable works.
CFLAGS+=-O3
CFLAGS+=-g0
include config.mk
# cross build
CROSS_COMPILE?=
######CXX:=$(CROSS_COMPILE)g++
######CXX:=$(CROSS_COMPILE) arm-linux-gnueabi-g++
CXX:=$(CROSS_COMPILE) aarch64-linux-gnu-g++
######CC:=$(CROSS_COMPILE)gcc
######CC:=$(CROSS_COMPILE) arm-linux-gnueabi-gcc
CC:=$(CROSS_COMPILE) aarch64-linux-gnu-gcc
But now when I execute "ctrlsw-decoder" on UltrazedEV carrier card I have this error:
VCU control software decoder sample app
Allegro DVT2 - AVC/HEVC Decoder Reference Software v1.0.41 - Copyright (C) 2018
Confidential material
Resolution : 1920x1088
FourCC : NV12
Profile : 100
Level : 40
Bitdepth : 8
Crop top    : 0
Crop bottom : 8
[ 2011.599298] Unknown ioctl: 0xC20C7102
Crop right  : 0
Display resolution : 1920x1080
Sequence pictu[ 2011.605078] Known ioctl are:
re : progressive
Buffers needed : 8 of size 3342336
[ 2011.613502] AL_MCU_CONFIG_CHANNEL:C2087102
[ 2011.622421] AL_MCU_DESTROY_CHANNEL:00007104
[ 2011.626604] AL_MCU_DECODE_ONE_FRM:C40C7105
[ 2011.630699] AL_MCU_WAIT_FOR_STATUS:C2047106
[ 2011.634875] AL_MCU_SEARCH_START_CODE:C4087108
[ 2011.639231] GET_DMA_FD:C00C710D
Codec error: Unknown error
What's the problem?
pierlum
Voyager
Voyager
Hi @watari ,
Thank you.
florentw
Hi @pierlum
The pg252 is pointing to the git repository. You are responsible of checking in for the correct branch corresponding to the version you are using.
The PG252 might not be updated every release so the most generic link is the one which is already present
Florent
pierlum
Voyager
Voyager
Hello @florentw ,
thank you for the informations. So next time when I find a git link in a PG I'll search for the correct branch.
