separated VDMA write and VDMA read
hi all
i have the ZCU106 xilinx evaluation board
i build design with HDMI input and HDMI output with one VDMA (write and read together) - and i can see video in the screen,
when i'm trying to separate the VDMA to 1 READ only and 1 WRITE only - i don't success to make them work correctly together.
i tried many options
anyone can help me ?
thanks.
Tags (2)
Hi assaf.regev@realityplus.io
You have to make sure each VDMA is aware of the other one using genlock.
I assume you have connected them as per figure 2-21 or figure 2-22 from PG020?
Florent
Any progress on this? Do you have a working design now?
Florent
yes i have a good  design now
thanks.
