standard exception: XNetlistEngine: file created for XST synthesis cannot be removed
Hi all,
I was looking for a explanation to this error message, I get while I am generating a .bit file, in order to avoid to get it:
standard exception: XNetlistEngine: An exception was raised: com.xilinx.sysgen.netlist.NetlistInternal: ERROR:coreutil - Temporary directory    (.\tmp\_cg\multiplier_virtex4_10_0_926e1797c81cb535_mult_gen_v10_0_xst_1_xsd)    created for XST synthesis cannot be removed at C:\My Dropbox\Archivos sobre mi PFC\Files_Matlab\System Generator\My components\ANFISF_components\ANFISF_REAL_Q1\sysgen\masterScript36474.pl line 4558
Does anyone could tell me how to solve this error?
Thank you!
Try clearing the cache.  There is a section in the User Guide that explains how to do this.
Also you should probably use directories that don't include a space in the name.  This often causes problems.
Also try to keep you path as short as possible, as long paths aslo can cause problems with XST>
Chris
Versal ACAP: AI Engines | Embedded SW Support
