system generator compatability
Does version 11.4/11.5 System generator work on a 64 bit system?  The compatablity page shows older versions for windows xp (32-bit only).  The newer versions do not say that.
Officially - no.
Practically - if you try to install SysGen on 64bit Matlab - it will simply not see it, and you will not be able to continue.
Solution, which I tested with 9.2 Version is to install 32bit Matlab on 64bit Windows and then Sysgen can be installed on it. Also ISE must be 32bit.
But then allmost all advantages of 64bit Windows are lost.
Officially - no.
