system generator token parameter can assign any valiable with M-file?
Hi everyone,
Can i assign a valiable to system generator token parameter and gateway in parameter with M-file?
I have tried the Simulink block digram. It can pass the parameter to M-file.
I have attached the file for references.
Yes, just write the variable name, or any more complex matlab expression in the dialog boxes, and use an M-script to initialise the variables that you use in those expressions.
Anywhere you can put a number in a simulink dialog, you can also put a Matlab expression.
Cheers,
Martin
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
Also note that the variable must be defined in the workspace.  If it is defined in an m-script this script must be run so that it can be found in the MATLAB workpace.
On a different note, if you go to file -> model properties in the .mdl, you can set callback functions to define a variable.
For instance, you can have a PreLoadFcn that sets a variable upon opening your .mdl that you can reference in your design.
