ha4456
there is a large violation between clkout2 and txoutclk_2 from PG235
the video phy interface is PG230.
Tags (2)
florentw
Hi @ha4456
Can you share a screenshot of part of your BD showing how the Video PHY and HDMI TX are connected?
Did you check that the connections were matching the example design?
Florent
florentw
HI @ha4456
Can you share your design? Without the design this is not really possible to tell what is wrong...
Are you using the Xilinx HDMI subsystem IP?
Did you check the HDMI example design? There is no timing failure there so it might be an issue with your design
Florent
watari
Hi @ha4456
Did you make sure fully path report at path 683 ?
According to summery report, it seems fine as total delay (logic delay (0.137 [ns]) and net delay (0.264 [ns]).
However, launched and captured clocks are different.
Does it need to synchronize them ?
If yes, I suggest you to add some constraint to resolve this issue.
- set_input_delay
  => add path delay constraint between two flip flops.
- Or, add location constraint. (Need to make sure fully path report to find proper location.)
If no, you try set_input_delay between two flip flops (Recommend) or set_false_path between two clocks (Not recommend).
If you don't know it, would you share the fully path report file at path 683.
Best regards,
ha4456
Yes, i use the native interface(PG235+PG230 ).
the violation is only relative with (PG235+PG230 ).
do you mean to send the dcp file?
The launch and capture clock are difference.
watari
Hi @ha4456
Would you launch the following command on tcl console on Vivado ?
report_timing -from <your start point> -to <your end point> -setup -path_type full_clock_expand
If you want to know more details about report_timing command, refer UG835 at page 1439 or the following URL.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug835-vivado-tcl-commands.pdf#page=1439
Best regards,
ha4456
watari
Hi @ha4456
I'm not sure whether this setup error is correct or pseudo.
But you might fix this error to change location of MMCME3_ADV, if possible.
=> Reduce clock net delay (4.698 + 4.702). The route cause is this clock net delay and it's related to location of MMCME3_ADV.
Best regards,
ha4456
how to find which MMCME3_ADV is nearest?
ha4456
the two clock can be set false path?
florentw
Hi @ha4456
Florent
ha4456
I don't use BD.
It is RTL-based.
florentw
HI @ha4456
Anyway, you should still start from the example design. You will see that there is no timing violation so it is probably a clock misconnected in your design or a constraint missing
Florent
