08-01-2013 08:23 AM
Sir,
In my system generator design I am getting an error: unable to create memory map of the file..xyz.mdl..
N.B: I am using floating point data type inside the system generator model..
Best
Chandrajit
08-16-2013 08:14 AM
Ok sir, I have used fixed point with enough precision and the problem got solved..
08-07-2013 09:24 AM
Hi ,
what else your design has?
Are you trying to bring bidirectional signals in black box ?
Can you please copy the mdl Block diagram here ?
08-16-2013 08:14 AM
