msadras
v4l2src0 Failed to allocate required memory when streaming two 4kp30 channels (multistream).
Xilinx Zynq UltraScale+ MPSoC ZCU106, using VCU TRD 2019.1, failed to allocate required memory when streaming two 4kp30 channels (multistream).
When streamilg one source of 4kp30 and one 1080p - works appropriately.
DDR - 2GB.
Is there any way to figure out how mush each video channel takes?
Mor
log:
2019-09-15 - 16:44:45 - [4]:media_configure:311 - called
0:00:06.534992842 25535 0x7f68010d40 ERROR v4l2bufferpool gstv4l2bufferpool.c:677:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool:src> error with STREAMON 22 (Invalid argument)
0:00:06.535236625 25535 0x7f68010d40 ERROR bufferpool gstbufferpool.c:564:gst_buffer_pool_set_active:<v4l2src0:pool:src> start failed
0:00:06.535366708 25535 0x7f68010d40 WARN v4l2src gstv4l2src.c:697:gst_v4l2src_decide_allocation:<v4l2src0> error: Failed to allocate required memory.
0:00:06.535480919 25535 0x7f68010d40 WARN v4l2src gstv4l2src.c:697:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed
0:00:06.535668637 25535 0x7f68010d40 WARN basesrc gstbasesrc.c:3275:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation
0:00:06.535734164 25535 0x7f8000f630 WARN rtspmedia rtsp-media.c:2722:default_handle_message: 0x7f8003e2a0: got error Failed to allocate required memory. (../../../git/sys/v4l2/gstv4l2src.c(697): gst_v4l2src_decide_allocation (): /GstPipeline:media-pipeline/GstBin:bin0/GstV4l2Src:v4l2src0:
Buffer pool activation failed)
0:00:06.535872607 25535 0x7f8805a0f0 WARN rtspmedia rtsp-media.c:2991:wait_preroll: failed to preroll pipeline
0:00:06.535899300 25535 0x7f8805a0f0 WARN rtspmedia rtsp-media.c:3295:gst_rtsp_media_prepare: failed to preroll pipeline
0:00:06.536058335 25535 0x7f68010d40 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
0:00:06.536173766 25535 0x7f68010d40 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
0:00:06.536626280 25535 0x7f8000f630 WARN rtspmedia rtsp-media.c:2722:default_handle_message: 0x7f8003e2a0: got error Internal data stream error. (../../../../git/libs/gst/base/gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:media-pipeline/GstBin:bin0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4))
0:00:06.538612603 25535 0x7f8805a0f0 ERROR rtspclient rtsp-client.c:1044:find_media: client 0x7f78859960: can't prepare media
0:00:06.538743916 25535 0x7f8805a0f0 ERROR rtspclient rtsp-client.c:2899:handle_describe_request: client 0x7f78859960: no media
2019-09-15 - 16:44:45 - [4]:client_close_handler:211 - called
2019-09-15 - 16:44:45 - [4]:client_close_handler:216 - [0] Client is closing down 192.168.67.1
2019-09-15 - 16:44:45 - [4]:new_client_handler:243 - called
2019-09-15 - 16:44:45 - [4]:new_client_handler:250 - [1] A new client has connected 192.168.67.1
2019-09-15 - 16:44:45 - [2]:new_client_handler:285 - Creating 'closed' signal handler
florentw
HI @msadras
Using 2*4K@30 streams require more encoder buffer than a single 4k@60 stream. You need to make sure the VCU is configured for 2*4K@30 streams in the VCU IP configuration.
Florent
florentw
HI @msadras
What is your input and what is your output? If you are trying to encode to a file, are you sure you have enough memory on the media?
Florent
watari
Hi @msadras
I encounter similar issue.
I guess you need the followings.
- Set suitable cma value on Linux kernl argument.
- Describe reserved memory area and size on VCU and memory section in device tree blob file.
I will try them to resolve my issue. But I have enough time to do it now...
Best regards,
msadras
cma value is 1700M now from 2G we have.
do you mean
vcu-modules
al5e, al5d:
al,mcu_ext_mem_size: specifies the size of the external memory of the mcu. default is MCU_SUBALLOCATOR_SIZE
al5r:
al,devicename: specifies the /dev/X name the created device should have. default is that the /dev/X node isn't created
Now the default value of MCU_SUBALLOCATOR_SIZE is 32M. Are we supposed to consider a bigger value?
Need to be added to VCU_vcu_0: vcu@a0100000?
VCU_vcu_0: vcu@a0100000 {
  #address-cells = <2>;
  #clock-cells = <1>;
  #size-cells = <2>;
  clock-names = "pll_ref", "aclk", "vcu_core_enc", "vcu_core_dec", "vcu_mcu_enc", "vcu_mcu_dec";
  clocks = <&misc_clk_1>, <&zynqmp_clk 71>, <&VCU_vcu_0 1>, <&VCU_vcu_0 2>, <&VCU_vcu_0 3>, <&VCU_vcu_0 4>;
  compatible = "xlnx,vcu-1.2", "xlnx,vcu";
  interrupt-names = "vcu_host_interrupt";
  interrupt-parent = <&gic>;
  interrupts = <0 96 4>;
  ranges ;
  reg = <0x0 0xa0140000 0x0 0x1000>, <0x0 0xa0141000 0x0 0x1000>;
  reg-names = "vcu_slcr", "logicore";
  reset-gpios = <&gpio 119 0>;
  encoder: al5e@a0100000 {
   compatible = "al,al5e-1.2", "al,al5e";
   reg = <0x0 0xa0100000 0x0 0x10000>;
  decoder: al5d@a0120000 {
   compatible = "al,al5d-1.2", "al,al5d";
   reg = <0x0 0xa0120000 0x0 0x10000>;
florentw
HI @msadras
Florent
aoifem
Hi @msadras
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
