dr.elichan
vdma genlock problem in hdmi passthrough application
I need to receive a non-steady  video stream and to transmit it as a steady video stream with different frame rate. I am now puzzling on what is the most viable ways to do it?
1) Scenerio one:
Hdmi in -> (Dynamic Genlock Master)VDMA 0(Dynamic Genlock Slave) -> Slow HLS IP(w/ non steady streaming output)  -> (Dynamic Genlock Slave)VDMA1(Dynamic Genlock Master)->Hdmi out
Is it viable to let HDMI out be connected to Dynamic Genlock Master of VDMA1? Will the "slow IP" manage to behave as a Master(?) to send axi4 stream to VDMA1?
2) Scenerio two:
Hdmi in -> (Dynamic Genlock Master)VDMA 0(Dynamic Genlock Slave) -> Slow HLS IP(w/ non steady streaming output  -> (Dynamic Genlock Master)VDMA1(Dynamic Genlock Slave)->Hdmi out
Can Dynamic Genlock Master of VDMA1 manage to read streaming from the "Slow IP"?
3) Another other alternatives?
florentw
HI @dr.elichan
The option 2 is the better in my opinion.
Most of the time you want the S2MM interfaces of the VDMA to be the Master. The reason is simple. If the MM2S is the Master then it will not care about what was the last frame to come into memory.
Thus what will happen is that it might read older frames than the last one displayed
Yes, it will take the time it needs to write the frame into memory
Florent
florentw
HI @dr.elichan
Florent
