tim_severance
video_phy mixed DisplayPort and HDMI
Hi, I am working on a Vivado 2017.4 Kintex 7 design where I need to implement a DisplayPort receiver and HDMI transmitter.   I am getting an error (see image below) telling me I cannot mix protocols.   Does this mean I cannot do a design with both HDMI and DisplayPort, or does it mean I just need to use two VideoPhy blocks in the block design?
Tim
xud
@tim_severance
It's known that single Video PHY doesn't support mixed protocol. However, you can add two VIdeo PHYs, one for HDMI and the other for Displayport.
- In HDMI Video PHY : RX sets to NONE, TX protocol is HDMI
- In Displayport Video PHY : TX sets to NONE, RX protocol sets to Displayport
xud
@tim_severance
florentw
Hi @xud,
Just to add on Xu's response:
If you need to use the same Quad for bothy DP and HDMI (so use a single VPHY), you will need to modify the VPHY which is provided as unencrypted HDL. However note that this is not a supported solution from Xilinx.
Florent
tim_severance
@xud / @florentw,
   Thanks for the answers, this explains the problem.
Tim
