what is the main stream video processing structure support by A7 FPGA?
This is the original post
https://forums.xilinx.com/t5/AXI-Infrastructure/Are-there-any-updates-for-xapp789/m-p/846543#M667
I am using A7 FPGA for a group of new projects. That seems a main stream video processing structure is quite necessary to be considered at the early stage. Generally the A7 fpga is working with 32bits DDR3 chip and DVP based cmos image sensors. It is required:
1) more than one channel video stream go into DDR3 frame buffer.
2) one or two video output channel sink the image data from ddr3. Such as HDMI output and USB3.0 output.
If any app note is created as common platform to my application? xapp789 is just looks like a legacy note.
Hi @rggber,
Do you have what you need? If yes, please kindly mark @tedbooth 's response as accepted solution to close the topic.
