timi
xapp1308 PICXO NCO output
I instantiated PICXO in NO_GT mode.
I adapted the setting from xapp1308 for generating 27 MHz clock from an 15.625 KHz hsync pulse.
I found the nco output(ACC_DATA[0]) to be a pulse rather than a clock, meaning the duty cycle is not 50%.
Furthermore the frequency of the nco output is not 27MHz as expected but 14MHz.
With this setup I generated a bitstream and forwarded the nco output to a board pin. I found the jitter to be very high - the edges were moving!
To sum up:
-> I dont have a 50% duty cycle clock
-> frequency of the clock is not 27MHz
-> a lot of jitter on this clock
Any help is appreciated!
P.S.: In the attachement REF_CLK_I is connected to my hsync pulse generator(currently 15.625 KHz).
Tags (2)
benoitp
@timi:
I recommend starting with the Example Design to get the NCO instantiation and connection as your starting point.
If your 15.625kHz HSync pulse is coming from a commercial device like the LMH1981 (Multi-Format Video Sync Separator, http://www.ti.com/lit/ds/symlink/lmh1981.pdf), keep in mind the stable edge is the "falling edge", so you'll need to invert (i.e. put an inverter in your FPGA) before connecting this signal to the REF_CLK_I of your PICXO NCO.
It is very important to push a reset (RESET_I port of the PICXO) on the PICXO NCO every time you change the video format of your REF_CLK_I port. You must see your ERROR_O oscillating around zero to confirm your NCO is locked.
I assume you are using the settings (R, V - hex, G1, G2, CE_DSP_RATE) for 576i (PAL) in Table 2 page 8, and values on page 9. For instance, HSync@15734Hz, NCO@27MHz, R=0, V=0x0D66, G1=01, G2=07, ACC_STEP=1, CE_DSP_RATE=0x01FF [5.5/1.000 --> C=0x59, N=5, P=4]. You may require to adjust the Fractional Pre-scale settings, refer to Table 3 and associated text.
You are correct, the NCO output won't provide a nice 27MHz clock: you'll get a "27MHz period signal" out of it, and it will look very jittery, but the goal/use-case of this NCO ref design is to push the "HSync reference" to a higher 27MHz frequency domain. The second PICXO stage (PICXO GT) will filter out this jitter and lock the TXOUTCLK to your reference.
I used 300MHz as free-running clock (so you'll get 3.33ns resolution) but 200MHz (5ns resolution) should work too.
Hope this help.
Benoit
florentw
Hi @timi,
Sorry about the delay on this. Are you still having issues on this?
If yes could you let me know:
  1. How is (are) the PICXO connected?
  2. What modifications were made to the original example design?
Thanks and Regards,
Florent
timi
Hi @florentw
The issue is still not solved.
The IP is connected according to figure 3 in xapp1308 but without the PICXO_GT.
I do not use the example design.
florentw
Hi @timi,
What is the clock frequency you are using to drive the PICXO core?
Florent
timi
Ok sorry.
It's 200MHz on the TXOUTCLK_I input
benoitp
@timi:
Hope this help.
Benoit
chenj15
I am using your reference XAPP1315 sample codes, my application requires a 1:6  deserialization. How should I change your sample code from 1:7 to 1:6?
Jim
ar2019
Hi @benoitp.
I am planning to add genlock support and found this topic. I hope you don't mind me asking here.
You are talking about how to setup NO GT PICXO. But we have second one after that. And that's where I am being very much confused.
I looked at the spreadsheet which comes with reference design and looked at xapp1241 but unfortunately that didn't clear what to do. Is there any help on it?
