zhouzeming
zcu 102 hdmi example can not open
首先,我刚得到一个ZCU_102板,并根据pg 235-vHDMI-TX-ss.pdf文档测试了HDMI接口,但是当我按提示打开示例时,Vivado总是提醒我打开的失败。我正在使用Vivado 2018.2版本。我剪了3张照片,下面是错误的内容,我下一步该怎么办?
“ERROR: see log file for details.
while executing
"error "ERROR: see log file for details.""
invoked from within
"if {[catch {source [file join $srcIpDir exdes_bdgen.tcl]} errMsg]} {
puts "ERROR: \[open_example_project\] Open Example Project failed: Error encoun..."
(file "d:/vivado_prj/zcu_102_prj/hdmi_test1/hdmi_test1.srcs/sources_1/ip/v_hdmi_tx_ss_0/v_hdmi_tx_ss_0_ex.tcl" line 120)“
florentw
Hi @zhouzeming,
As this is solved, could you kindly close the topic by marking the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
watari
Professor
Professor
Hi @zhouzeming
Do you have an evaluation license or purchased license for HDMI ?
At least, vivado requests this license.
Best regards,
zhouzeming
Yes, I have license, this screenshot is the details of the license.
chinmays
Hi @zhouzeming,
Video test pattern generator has the feature name "v_tpg". In the provided screenshot I can't see "v_tpg" . For knowing status the IP go to IP catalog, search "tpg", right click on "Video Test Pattern Generator" and select "license status". Refer to AR#66350, which precisely address this issue.
Chinmay
zhouzeming
Thank you for your reply, I follow the link that you sent and search for "v_tpg" and there is no relevant license. I tried to regenerate a new certificate, but it still didn't work. Do I need to reinstall VIVADO 2018.2?
florentw
Hi @zhouzeming,
Please login into your licensing account. Then search for the test pattern generator in the No Charge cores:
Then generate the license for it.
Hope that helps
Florent
zhouzeming
Thanks for your help and the problem has been solved。
florentw
Hi @zhouzeming,
Thanks and Regards,
Florent
