zcu106 vcu TRD DP GUI show only OSD but not video
Hello i'm working with zcu106 and I'm testing with TRD. I selected as input hdmi-Rx, enc-dec mode and as output Display port. I start the GUI where i can see the informations about vcu and processor. It says that hdmi source is 1080p 60fps or 1080p 24fps according to input video so hdmi video is correctly received. Tha strange thing is that I can't see video on DP but only GUI+ black video. I'm making some mistake?
Thank you.
Hi @pierlum,
I am not sure the VCU TRD can work in HDMI -> DP.
Could you try to decode a video and display it to the DP controller or use the Test Pattern Generator? This would be a first step.
Then it is working, you might want to make sure you are actually receiving data on HDMI.
Hi @pierlum,
Thanks and Regards,
Hi @florentw,
sorry for the late reply. Making some tests I saw video output using hdmi output using CLI on UART and for me this was enough. On display port only OSD and no video but it's not important for me.
