Newbie eric-kuo
12G-SDI resolutions on Kintex-7
I have one question about the available video resolution in Xilinx LogiCORE UHD-SDI.
In the document “SMPTE UHD-SDI v1.0”, table 2-7 shows the resolution up to 2048x1080, and there is no option for 4096x2160.
However, in the document “SMPTE UHD-SDI Receiver Subsystem v2.0,” it shows the testing condition includes 4096x2160.
Is anyone know if the 4096x2160 can be run on Kintex-7?
Thanks a lot!
Re: 12G-SDI resolutions on Kintex-7
Hello @eric-kuo,
Yes, the 4K resolution is supported by the example design mentioned in the product guide but we don't have any example design in the VIVADO available for 7-series devices supporting the similar resolution.
Refer XAPP1249 to run UHD-SDI design on Kintex-7.
https://www.xilinx.com/support/documentation/application_notes/xapp1249-smpte-sdi-interfaces-7series-gtx-transceivers.pdf
The maximum resolution supported is 3840x2160p60hz which fits your 4K requirement.
Thank you
Hello @eric-kuo,
Thank you
HI @eric-kuo,
The UHD-SDI RX subsystem includes the UHD-SDI IP under the hood. So the testing for the UHD-SDI RX SUbsystem is applicable to the UHD-SDI IP
Newbie eric-kuo
Hi, Kvasantr,
Thanks for your reply. It is a good news to me.
Thanks a lot!
Newbie eric-kuo
Hi, Florent,
Thanks for the explanation and confirm.
Best Regards,
