[2018.1 / 2017.4]HDMI RxStreamDownCallback problem
I have a question about HDMI RxStreamDownCallback function. Why  does Xilinx add "TxRestartColorbar = (FALSE);TxBusy = (TRUE);" in vivado 2018.1 ?
Vivado 2017.4
void RxStreamDownCallback(void *CallbackRef)
  IsPassThrough = (FALSE);
#ifdef USE_HDCP
  /* Call HDCP stream-down callback */
  XHdcp_StreamDownCallback(&HdcpRepeater);
#endif
Vivado 2018.1
void RxStreamDownCallback(void *CallbackRef) {
#if(LOOPBACK_MODE_EN != 1)
#ifdef XPAR_XV_HDMITXSS_NUM_INSTANCES
	    ResetAuxFifo();
		/*Check for Pass-through*/
		/* Doesnt require to restart colorbar
		 * if the system is in colorbar mode
		if (IsPassThrough) {
			/* RX Stream Down happen due to 2 possible scenarios
			 * 1 - When resolution change
			 * 2 - When the source stops sending stream even the RX cable
			 *     is connected
			 * In this example, The color bar should happen only for 2
			 * scenarios, when the TX Cable is still connected
			 * 1 - When pressing "c" by forcing the color bar
			 * 2 - When RX cable is disconnected
			 * Hence, when the stream change, the example design
			 * wouldn't enter to color bar mode unless both scenario's32
			 * above
			TxBusy = (TRUE);
#endif
#endif
#ifdef USE_HDCP
#endif
Sitting
Tags (2)
Re: [2018.1 / 2017.4]HDMI RxStreamDownCallback problem
@sitting
I think the comments is clear enough, TxRestartColorbar is used to avoid using color mode when RX is changing resolution. "Hence, when the stream change, the example design wouldn't enter to color bar mode unless both scenario's32 above"
Hi @sitting
To clarify: this function is included in the application source code for the example design. Specifically in xhdmi_example.c.
In the old code, I believe there was a conditional statement that checked for IsPassThrough, if it was false then the TPG was started to produce a video stream to the TX.
In the new code, TxRestartColorbar = (FALSE), and TxBusy = (TRUE) are used.
TxRestartColorbar is a flag used to call:
HdmiTxSsVidStreamPtr = XV_HdmiTxSs_GetVideoStream(&HdmiTxSs);
             EnableColorBar(&Vphy,
                         &HdmiTxSs,
                         HdmiTxSsVidStreamPtr->VmId,
                         HdmiTxSsVidStreamPtr->ColorFormatId,
                         HdmiTxSsVidStreamPtr->ColorDepth);
TxBusy is a flag that represents:
"Either TX still on transition to a new video format    "or the TX cable is not connected"
Sam
Sam
Xilinx Video Design Hub
@sitting
