3G -SDI Implementation on Zynq Ultrascale + Dev. Kit
I want to implement a design to capture 3G- SDI inputs at various resolutions and output them across HDMI & 3G- SDI output.
Is it possible to implement this on Zynq Ultrascale +  ZCU102 development board? If yes, I would like to understand the implementation on a higher level to proceed with design using Vivado.
Also an example design link would be much more useful.
Vinay Shenoy
Vinay Shenoy
Tags (2)
Scholar watari
Re: 3G -SDI Implementation on Zynq Ultrascale + Dev. Kit
Hi @vinay_shenoy
Would you refer XAPP1285 ?
You can find description of video scaling.
https://www.xilinx.com/support/documentation/application_notes/xapp1285-scaling-video-processing-with-vpss.pdf
Best regards,
Hi Vinay,
Xilinx has an example design for HDMI on zcu102 (refer to the chapter 5 of the HDMI product guide) and an example of UHD-SDI (can do 3g) on zcu106. You would have to mix both design.
Note, you might want to look at this topic for Sdi on zcu102:
https://forums.xilinx.com/t5/Video/UHD-SDI-Example-design-ZCU102-Version/td-p/838948
Florent
Hello @florentw
Thank you!
I have to do some video processing here. The HDMI/3G- SDI inputs can be of different resolution. I need to scale them to 4K (Only in case of HDMI/ DP outputs). I don't find any much video processing in the example designs. Could you please let me know the best way to implement this.
Vinay Shenoy
Vinay Shenoy
Scholar watari
Hi @vinay_shenoy
Best regards,
I will check that out.
Vinay Shenoy
Hi @vinay_shenoy,
Do you have any updates on this? If everything is clear for you, please kindly mark @watari reply as accepted solution.
Thanks and Regards,
Florent
