4K@30fps Multistream Decoding and Encoding
I am using Zynq Ultrascale+ MPSoC ZCU104 to multistream transcoding of two videos at 4K@30fps.
I connected to my board via Tera Term. And for decoding them I use the command:
gst-launch-1.0 filesrc location=bbb_sunflower_part1.mp4 ! qtdemux name=demux1 demux1.video_0 ! h264parse ! queue ! omxh264dec ! queue max-size-bytes=0 ! filesink location="output_0.yuv" filesrc location=bbb_sunflower_part2.mp4 ! qtdemux name=demux2 demux2.video_0 ! h264parse ! queue ! omxh264dec ! queue max-size-bytes=0 ! filesink location="output_1.yuv"
The same format has been worked for 2 videos at 1080p30fps. But this time I get the following errors:
Can somebody please help me? I am stuck :(
Tags (3)
Re: 4K@30fps Multistream Decoding and Encoding
Hi @yildizbilgin
Did you try all the option from the debugging section of the PG252? In particular did you try to change the CMA size?
Also on which stortage device are you saving the stream? You probably do not have enough space on your memory card. Maybe try to use an external drive
I am using a 16 GB SD card. I dont think I dont have enough space on my SD Card because I can encode and decode these videos one by one.
I dont understand how I can change CMA size.  I try this:
cma=250M
And nothing happened.
Hi @yildizbilgin
The command cma=250M needs to be entered in u-boot each time the device boots.
You can also do it in the kernel configuration when builing your petalinux project:
In the kernel config (in petalinux, run petalinux-config -c kernel) change the size of the CMA under
-> Device Drivers
-> Generic Driver Option
-> DMA Contiguous Memory Allocation
-> Size in MegaBytes
-> Device Drivers
It was 1000 and I made it 2000.  After that I build the pre-built images again. Nothing changed.
HI @yildizbilgin
What version are you using? 2018.3 or 2019.1?
I am using 2019.1
Hi @yildizbilgin
I missed this previously but you need to make sure the VCU IP in your vivado design is configured for 2*4K@30 streams because it will require more encoder buffer memory than for a single 4k@60. This is maybe why you cannot do the mutlistream.
From pg252:
Hi @yildizbilgin
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
